LED door pad projector
#41
I had one die within a week, but the supplier replaced it. The 2 on now have worked fine for a few months, but the image on one rotates a little every time the door is closed. Taking the dead one apart I see neither the Mustang slide nor the barrel that it and the lenses sit in are anchored to the case, so I've just put up with it. Taking it apart and adding a drop of glue might take care of the problem, but I haven't gotten my round tuit located to do that yet.
#43
Are these lights still operational for you all? That seems like a very original mod!
Seems like the quality is cheap? It is something that I might do, but I wonder what all of you think as far as what the longevity really is before it needs replacement.
And I dont have any footwell lighting yet but I want to put that in.. can the pillar point that you tapped into for power handle the xtra load of both those mods?
I am a total newb for wiring (just installed aux piece for the shaker 500 and got kinda spooked when I noticed my electrical tape was gooey, but I think that was there before I bought it cause the wires are not hot to the touch after a few idling tests), but I guess I enjoy tweaking/adding things.
#44
I had some problems with my original installation of the door pad projectors in that the image would rotate within the cylinder every time the door closed and one that burned out. I bought a newer generation (uses spring clips rather than retaining nuts) and they produce a smaller, more attractive image and have had no issues with the image rotating. I am liking it a lot better.
