iPod AUX adapter for Shaker
Old Oct 15, 2008 | 02:38 PM
jodadejSS06GT's Avatar
Hey everyone I purchased this package to be able to use the stock Shaker 500 AUX button with my Ipod. This little box gives you RCA outputs. I used an iPod cable that goes from RCA's to the head phone jack. You can find them at any big audio place(etc. Best Buy, Crutchfield, Circuit City).
Note:
A voltmeter is always a great tool to start with when wiring radio equipment.
First follow TacoBill's Hotlink for Metra Amplified Windshield Antenna Install. http://forums.bradbarnett.net/showthread.php?t=445173
Follow through removing the 4 bolts that hold in the Shaker 500 head unit.
There are many different locations to route the cable; I chose the snap in plastic panel inside the arm rest on the driver’s side.
Measure your headphone jack diameter and select the appropriate drill size.
I measured and marked the center of the panel with tape and a pen
The plastic is real soft so I chose to get the hole started with the shown drill bit before using the 13/32"
From this point I followed TocoBill’s advice in his windshield install in using Pin 2 on the J1 connector.
You need to wire the harness to 12V power and also ground. He chose the pin 2 because it only comes on when you key on, the one I initalled it too is 12V all the time. I need to go back and fix that.
Note: This didn’t initially work for me because I blew a fuse in the passenger side floorboard box (took a while to figure that out) so my adapter wasn't initally working, so I hooked up to the direct 12V to the ((+)in the diagram) and the ground to the ((-)in the diagram) until I have a chance to switch back over to Pin 2
I mounted the box here, forgot to take pictures but you can imagine it sitting there with 3M double sided tape.
The best place to route the wires in my case was along the bundle that runs under the cup holders to the parking brake. The wire tapes nicely to the wires. I also had extra slack with the 7’ cable.
The final outcome!!!
Send me comments or questions
Reese
Old Oct 15, 2008 | 02:57 PM
Looks great!
Hopefully others thinking of doing the samething can use this as a guide.
Old Oct 15, 2008 | 03:20 PM
06GT4RAD's Avatar
I thought there was a thing that just plugged right into the back of the deck to allow use of the iPod.
Am i mistaken or am I missing something in your directions?
Old Oct 15, 2008 | 04:10 PM
You are correct, this item does plug in.
http://enfigcarstereo.com/shopsite_s...FRD04_AUX.html
This is the item I forgot to show the pic, but the one pic I have an arrow of is where i 3M taped that down. It's basically an inline harness with a small little box that interupts the input to the radio allowing the input to be your ipod. You also have to power and ground it! Does this answer your question?
Old Oct 15, 2008 | 04:26 PM
05stangkc's Avatar
http://forums.bradbarnett.net/showth...highlight=ipod
Here is another Approach of Note.
Kc
Old Oct 15, 2008 | 07:46 PM
06GT4RAD's Avatar
Yes it did thanks
Old Oct 22, 2008 | 09:48 PM
kanicas's Avatar
Yes, it's called itriptunes, but you can't use your AUX button. You must set your radio station to one of three options to get the signal to the speakers. Much more simple that this install but I bet doing it like jodadejSS06GT will give you better quality sound. I can't complain I love my itrip tunes. I think it sounds great but I have not heard jodadejSS06GT system. I'm sure it's sweet.
Old Oct 24, 2008 | 04:32 AM
BigWorm2005GT's Avatar
Try this: http://www.crutchfield.com/App/Produ...G&tp=120&avf=Y
I almost went with this one myself. The advantage here is that you can drive the iPod from the Shaker deck, it charges the iPod, and it has a second input for HD Radio, Bluetooth, or some other audio device.
In the end, I went with an aftermarket deck that included all three (Bluetooth, iPod, and HD Radio). But if you want to keep the Shaker deck, this one I'd look hard at.
BW
Old Oct 24, 2008 | 07:30 AM
This past weekend I wanted to compare my iPod to an mp3 cd with the same song. I couldn't tell a difference between the two; they both sound really good.
I just went with this connection because it’s so much easier to update a playlist on the iPod rather than burning a new cd.
I like the charging capability, but I use my iPod for the gym and at work also. If you constantly charge your battery, the life of it will suck. I'd rather just have an external charger to plug in when I need it. Besides, its way easier to scroll through a playlist to find a song on the iPod rather than on the factory radio's crappy display.
It comes down to what you prefer.
Old Oct 29, 2008 | 05:05 AM
MaverickMLFD371's Avatar
use the BrandMotion kit, the best kit on the market for the ipod hookup!
Old Oct 29, 2008 | 04:17 PM
Clark Kent's Avatar
wow for how much it costs to add ipod support...you might as well go for a new HU IMO
Old Oct 30, 2008 | 09:40 PM
kanicas's Avatar
BW
I tried one of these can't remember the brand but my car did not like it. It caused electrical problems. I didn't believe the dealer that the ipod hookup was causing so many issues because it was fine for 5-6 months. After they removed the device everything was fine. I'm happy with what I have now only because it feels safe
Old Oct 31, 2008 | 04:27 AM
Clark,
That's what I ended up doing. I took a look at the options and decided that that made the most sense. But if you want to keep the Shaker (some do), there are options out there.
BW
Old Oct 31, 2008 | 11:23 AM
another 06gt's Avatar
Is their any differnce using the Iphone. I will be picking one up next week
Old Nov 3, 2008 | 12:54 PM
kanicas's Avatar
With the itrip tunes there's no difference.
duppycat
Feb 16, 2019 08:36 AM
yabutt
Oct 23, 2015 01:05 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
