Emergency Brake Boot
#41
Unfortunately mine is starting to rip at the front at the seam. Seems to be too much tension there and not enough material for full upward movement. I am not saying this to knock Jim's work however. Just some feedback to consider for the design. My boot just needed a little more material so it will not bind when pulling the brake up.
#42
Try setting the leading edge back further - should give more slack.
If not, maybe I can do something if you send it back?
PM me with issues. No one PMs me, so I have no idea if there are difficulties. Mine is going on 3 years and is fine, so it may be it is set too far forward?
Cheers
Cheers
#43
You can`t just flip it end for end , spin it around I almost put mine in backward one day , why I thought of this
#44
Cheers
Cheers
#47
For those of you for whom I am making a boot or shifter, I started yesterday, and will continue every evening until done - by Saturday, I estimate. PMs will be sent out when done.
Also, I'm looking at doing something for the 2010 - 11.
#49
#51
I got mine and installed it Sunday. Beautiful construction and great directions.. It was a breeze. even a girl can do it! I'm going to try to post a picture this weekend.
Thanks Javier
Thanks Javier
