Auto-dimming rearview mirror
Old Oct 27, 2005 | 11:36 PM
  #121
TinPony2's Avatar
tmcolegr...... I sent you a PM , I could use those instructions
Pls email me..
Old Oct 28, 2005 | 05:46 AM
  #122
Tiberius1701's Avatar
FYI complete Homelink programming instructions can be found at this address.
http://www.homelink.com/home/home.tml
Old Nov 2, 2005 | 08:16 PM
  #123
BeachPony's Avatar
Originally posted by ChrisM@May 31, 2005, 10:12 AM
You can't use the map light circuit for a simple tap for a grounded item as it will cause your map lights to stay on all the time. Any item that requires a hot side plus ground needs a tap off the fuse box.
FYI - I installed a autodimming mirror from 90's Cadillac and just tapped the power wire for the mirror into the black/blue stripe wire and the ground into the solid black wire. Everything works fine-no troubles. The factory service manual shows the black/blue stripe as a constant hot wire and the solid black as a ground.
Rob
Old Nov 29, 2005 | 09:18 PM
  #124
mrkabc's Avatar
I finally installed my Gentek G50 with compass/temp/and Homelink! What a PITA this was.
Since I have a vert the process was a little different - no headliner to hide that large, bricklike Molex connector built in to the wiring harness. I had to lunch it and solder/heatshrink the wires in order to lower the profile of the wiring harness.
I have a RED wire (switched power supply) and a YELLOW wire (no idea) in the harness. The manual sucks. There is no reference to a YELLOW wire for a setup without map lights (which I don't have.)
Talk about crypic instructions.
Electrochromatic works great. The vacuum fluorescent display could be a bit brighter though. Also, the Homelink buttons aren't lit - at night I can't see where to press to open my garage door!!! WTF?
Old Nov 29, 2005 | 10:54 PM
  #125
thestoogeo's Avatar
I second the garage door button lights. What were they thinking?
Jon
Fedupdave42169
Oct 23, 2015 09:58 AM
MRGTX
Sep 16, 2015 08:08 AM
Earlsays
Sep 12, 2015 06:29 PM
