upper grill replacement
No real trick to it....it's just a bit tricky. It also helps, if you can get some help....in the form of someone pulling a bit on the grille, as you work the clips. The clips are hard to push with just your fingers, so use a small screwdriver behind them as a lever, to pry them out just a bit, while you or your helper pulls just a bit on the grille. Work on just a couple of them at a time....once you get a couple of them loose, the slack created will usually let the rest of the clips pop past the locking notch pretty easily and the whole thing will come right out. If I remember correctly, I worked on the vertical side clips first...once they were loose the grille popped right out.
