upper grill replacement
Old Jun 28, 2007 | 09:41 AM
364's Avatar
364
I know this is going to sound dumb, but I'm trying to replace my upper grill and I can't figure out how to pop the 8 retaining clips that are holding the grill in place. I know were they are located, but I can't get them to release, and I'm afraid I'm going to bust them. Is there some trick?
Old Jun 28, 2007 | 10:01 AM
Sabre's Avatar
No real trick to it....it's just a bit tricky. It also helps, if you can get some help....in the form of someone pulling a bit on the grille, as you work the clips. The clips are hard to push with just your fingers, so use a small screwdriver behind them as a lever, to pry them out just a bit, while you or your helper pulls just a bit on the grille. Work on just a couple of them at a time....once you get a couple of them loose, the slack created will usually let the rest of the clips pop past the locking notch pretty easily and the whole thing will come right out. If I remember correctly, I worked on the vertical side clips first...once they were loose the grille popped right out.
Old Jun 28, 2007 | 10:55 AM
ShowGT's Avatar
These projects really need an extra pair of hands here. You don't want to scratch anything either, because then the money you save will be gone a new coat of paint.
Old Jun 28, 2007 | 11:26 AM
364's Avatar
364
Thanks Guys. I was was trying to pop them with my finger and just wasn't getting anywhere. I appreciate the help.
lakersfreak
Jun 13, 2022 12:29 AM
kponypower
Jun 17, 2020 07:17 AM
Gill5oh
Oct 6, 2017 10:50 PM
trackpack13gt
Oct 2, 2015 08:20 PM
