Sequential tailights/splice kit
Old Feb 12, 2007 | 07:23 PM
Fman67's Avatar
Who here has done the less expensive splice kit for the sequential tailights? How does it work...are you happy with it? Thanks in advance
Old Feb 12, 2007 | 08:17 PM
RadBOSS's Avatar
Get the turn key exchange kit from web electric ... in 30 minutes its a done deal and nothing else to mess with.
Old Feb 13, 2007 | 05:52 AM
YALLER's Avatar
Or get the Silverhorse Racing set
Just install their plug-n-play set on an '06
The kits are different, so make sure you get the right
one for your year model ('05 - nov '05)(nov '05 and up)
Ford changed the wiring harness during nov '05
Check out their website for the details.
Old Feb 13, 2007 | 06:10 AM
Mxyzptlk's Avatar
I'vfe got the meter4it kit. I installed it on my lunch break at work. Had it for about 9 months. I am happy with it.
Old Feb 13, 2007 | 06:17 AM
mikes rx's Avatar
I also recommend just getting the PNP kit. Time is money, and this is just too easy. Also, you can easily pull it if you wanted to. You don't have to return the old harness if you don't want to..
Old Feb 13, 2007 | 06:19 AM
BILLB60's Avatar
I did the 07 kit which where you have to replace the inner socket. But I forgot to do last step and only two outer lights work. I after undoing and redoing all the wiring, I noticed that I forgot step E. After tapped into the right wire wallah all works. Just follow all steps and cover bumper cover very well or you will scratch the thin clear coat taking lights in and out.
Old Feb 13, 2007 | 07:06 AM
05Stang_WI's Avatar
My kit was is from web electric - bascially factory harness replacement - very easy. I did opt to run a wire from the passenger side junction box to the rear to stop the brake lights from sequencing once. (you get one sequence before they stay on solid without this extra work). - Well that's with this kit anyway. I did it myself and started no fires.
Like others said here it's one of the easier mods to do - I'd go for it.
Old Feb 13, 2007 | 07:14 AM
mikes rx's Avatar
Originally Posted by 05Stang_WI
...I did opt to run a wire from the passenger side junction box to the rear to stop the brake lights from sequencing once. (you get one sequence before they stay on solid without this extra work).
I did the same thing, so it made the job take about twice as long as it should have (still only 30-45 minutes total)
I too didn't want the brake lights to sequence, because I thought for sure that the police would get me for that. Also, someone could say that they didn't know I was stopping, leading to other issues.
Old Feb 13, 2007 | 08:52 AM
backafter20's Avatar
I did the Webelectric splice-in version. It was not hard if you just follow directions. The second one only took a few minutes because I knew what I was doing after the first one. They work great, and the only drawback is that it would be difficult to remove and keep them if I sold the car. Then again, mine's and '05 and the harnesses probably wouldn't work on anything else anyway. The PNP version might be a bit easier, but it wasn't worth the extra money for me. I say go for it.
Old Feb 14, 2007 | 12:59 PM
Sharky's Avatar
I had a cop tell me that my tails were cool? Wanted to know where I got em'.
I don't believe there are any legal issues.
But I have always wanted to RAM into a camo painted 4x4 and testify that I hit it because I couldn't see it.
Old Feb 14, 2007 | 02:52 PM
mikes rx's Avatar
Where I live, they will get you for pretty much anything. For example, I know someone that ticketed for his FACTORY tint on his Tahoe, because it was "too dark". But, it is factory (therefore it can't be removed), and it IS legal because it is an SUV, not a car.
Even if the taillights are legal, it does attract officers so that they may get you for something that is illegal (ie-speeding)
Old Feb 14, 2007 | 04:10 PM
ryan1112's Avatar
I also did the splice kit. As Jim said, it's not hard if you just take your time and follow the directions. The second side is a snap after you figure it all out.
If you have never in your life stripped a wire you may not want to try it. I also soldered mine in, but it is not required. If I had to sell my car and wanted to keep them I would just resolder it back to stock.
Here are pictures of what you get and how the stock wiring looks after you are done splicing.
Attached Thumbnails Sequential tailights/splice kit-05install.jpg   Sequential tailights/splice kit-p1010151.jpg
Old Feb 14, 2007 | 06:49 PM
delz05's Avatar
I'va had the Web Electronics "spliced kit" since March 06, no troubles, took about 30 mins to do both sides. Used the money "not spent" on some MGW pieces.
Old Feb 14, 2007 | 07:25 PM
korinwoodo's Avatar
You just made my day man. haha
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
GeoWett
Sep 30, 2015 06:40 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 16, 2015 06:44 PM
