Lowered stangs and oil changes
Old Jul 28, 2006 | 12:13 AM
TexaStang's Avatar
As it stands, with a CDC classic chin spoiler I barely clear my rhino ramps for oil changes. What tricks do you guys use to make it up ramps like this?
Also, I'd be terrified to take it to the dealer for service of any kind, fearing they'd just drive up the ramps there and tear off the chin spoiler.
Are my fears unfounded? Some Steeda Ultralites are in my future, so just trying to figure this out ahead of time.
Old Jul 28, 2006 | 12:17 AM
mustangspeeder's Avatar
Change it yourself?
Lots of shops have wells also that you drive over and the tech can just walk downstairs under the car. Mine is lowered AND has the Cervini's side exhaust and I still fit over wells. I have 3" clearance at the bottom of the pipe for the exhaust, you'll still have plenty of room if you're just lowered and no side exhaust.
Old Jul 28, 2006 | 09:17 AM
TexaStang's Avatar
I just said I barely clear my rhino ramps for oil changes as it is. MY ramps, as in the ramps I use to change the oil myself.
Old Jul 28, 2006 | 09:24 AM
MTAS's Avatar
I put a 2' long 2x10 in front of each front tire and drive up on that. Gives me just enough room to get the floor jack under the car.
Old Jul 28, 2006 | 09:50 AM
TexaStang's Avatar
That's a good idea right there, looks like I'll need to do a trip to the lumberyard.
Old Jul 28, 2006 | 10:05 AM
MTAS's Avatar
See if they have any scraps they'll either give you or sell cheap
Old Jul 28, 2006 | 02:43 PM
scramblr's Avatar
Ummm, a lift? Sorry...one of the benefits in the Military...our own Auto Hobby Shops with all the toys at most bases...
Old Jul 31, 2006 | 06:27 AM
05YellowGT's Avatar
I picked up two 2'x4'x1/4" sheets of plywood. I then tacked a 2x4x2' on on one end of them and and another 1'x2'x3/4" piece of plywood on the opposite end , I probably should have used 3/4" for the two sheets too for more clearance. The ramps then fit on the sheets of plywood between the 2x4 and stacked plywood. I pull the car onto the end that has the stacked plywood and center the ramps on the wheels. The weight of the car holds the plywood sheets in place and the 2x4 on the opposite end stops the ramps from sliding as I pull on ...
Old Jul 31, 2006 | 10:50 AM
I've already travelled down this path...
I have the Steeda Ultralites, CDC Classic chin spoiler and Rhino ramps.
A couple pieces of 2x4 work just fine for me.
btw- That's my special 'Anti-Slip' mat (aka. roof shingle) that my Rhino's are sitting on.
yabutt
Oct 23, 2015 01:05 PM
southern stang
Sep 26, 2015 04:19 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
