installing headlights
i bought new headligths for my stang , i treid installing them but i cant seem to figure it out ( i also got new fog ligths anybody got a clue how to do it )
PS: i will post some pics of them later
I am assuming you are speaking of the headlight assembly. To install headlight assembly, you will have to do remove / detatch the front bumper cover. I found some instructions, but I have them at home. I will post when I get home from work this afternoon if no one else does.
You will have to remove the front bumper for this, it's super easy. you will have to remove the inner fender slpash guards to take off the 2 bolts on either side of the bumper. Then under the front bumper there is 7/32 screws that need to be removed. And finally there are 2 bolts on the upright posts (on either side of the grill, under the hood).
This should take you like 10 minutes tops. Check my link to my bumper conversion adn there are better pictures there.
Good luck
Jesse
Good luck
Jesse
Meet Krissy, Our Star Racer
it's not hard work but it didn't take me 10 minutes. there are instructions with the saleen headlights on how to do it - try and search online for them or i can scan them for you if you'd like.
as mentioned, remove front wheel well liners, remove screws along bottom and side of bumper, remove top screws and it helps if you remove the top plastic cover that sits over the top of the rad. then there are screws holding the headlight housings in. to get the bumper off, it takes a bit of muscle to actually get it off - you feel like you're going to break it actually.
gl
The saleen directions are good to go, the best part is they tell you what size sockets to use at each step (usually 10mm).
But I will stand behind my statement that it is super easy, a few bolts, tug the bumper and it's off. Although this is much like Rachels Ray's 30 minute reciepes, as long as the prep work is done the job can be accomplished in 10 minutes.
- Jesse
- Jesse
9/10/15 12:44 PM
