installing headlights
Old Feb 16, 2007 | 06:01 AM
SteveMcqueen's Avatar
i bought new headligths for my stang , i treid installing them but i cant seem to figure it out ( i also got new fog ligths anybody got a clue how to do it )
PS: i will post some pics of them later
Old Feb 16, 2007 | 07:00 AM
dustindu4's Avatar
9 is not my lucky number.
bulbs or the whole unit?
kryptonite's Avatar
I am assuming you are speaking of the headlight assembly. To install headlight assembly, you will have to do remove / detatch the front bumper cover. I found some instructions, but I have them at home. I will post when I get home from work this afternoon if no one else does.
Old Feb 16, 2007 | 07:15 AM
2L8IWON's Avatar
You will have to remove the front bumper for this, it's super easy. you will have to remove the inner fender slpash guards to take off the 2 bolts on either side of the bumper. Then under the front bumper there is 7/32 screws that need to be removed. And finally there are 2 bolts on the upright posts (on either side of the grill, under the hood).
This should take you like 10 minutes tops. Check my link to my bumper conversion adn there are better pictures there.
Good luck
Jesse
Old Feb 16, 2007 | 07:17 AM
MaverickMLFD371's Avatar
these might help you
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 16, 2007 | 08:23 AM
Rondosa's Avatar
Meet Krissy, Our Star Racer
Good luck
Jesse
easy there cowboy, i wouldn't say they are SUPER easy to do! :P
it's not hard work but it didn't take me 10 minutes. there are instructions with the saleen headlights on how to do it - try and search online for them or i can scan them for you if you'd like.
as mentioned, remove front wheel well liners, remove screws along bottom and side of bumper, remove top screws and it helps if you remove the top plastic cover that sits over the top of the rad. then there are screws holding the headlight housings in. to get the bumper off, it takes a bit of muscle to actually get it off - you feel like you're going to break it actually.
gl
Old Feb 16, 2007 | 12:41 PM
2L8IWON's Avatar
The saleen directions are good to go, the best part is they tell you what size sockets to use at each step (usually 10mm).
But I will stand behind my statement that it is super easy, a few bolts, tug the bumper and it's off. Although this is much like Rachels Ray's 30 minute reciepes, as long as the prep work is done the job can be accomplished in 10 minutes.
- Jesse
Old Feb 16, 2007 | 01:03 PM
kryptonite's Avatar
Took me longer than 10 minutes to remove the bumper cover, pull the old headlight assemblies and install the new ones.
Old Feb 16, 2007 | 11:07 PM
mhhh my head ligths and fogs have more cables than they are on the original unit
Old Feb 16, 2007 | 11:18 PM
here are the pics of the headlights/fog ligths
Attached Thumbnails installing headlights-dsc00228.jpg   installing headlights-dsc00229.jpg   installing headlights-dsc00230.jpg   installing headlights-dsc00231.jpg   installing headlights-dsc00232.jpg
JonsMustang
Mar 5, 2016 05:44 PM
CoyotePremium13
Sep 23, 2015 06:45 PM
50Cal
Sep 17, 2015 06:43 PM
Sep 10, 2015 12:44 PM
SMOKE46
Sep 6, 2015 09:40 PM
