help-need to remove and retape 1 razzi window scoop
Old Feb 18, 2006 | 05:28 AM
drno's Avatar
one of the corners is lifting on my razzi window scoop. any hints on removal as i need to retape and re apply it. there was no adhesion promoter applied -just straight tape.
Old Feb 18, 2006 | 06:35 AM
redbullet's Avatar
<div class='quotetop'>QUOTE(drno @ February 18, 2006, 7:31 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
You can use fishing line to remove the scoop from the vehicle and then paint cleaner to clean off the paint. The scoop will need to have the old tape removed and new tape applied. You can get this from a paint supply house.
3M makes a Automotive Adhesion Promoter #4298 You might find some at the supply house, if not, I ordered mine off the net. Do a search for the promoter and it will come up. I had to by the whole box but it has come in handy for applying all the other stick on stuff.
Old Feb 18, 2006 | 08:55 AM
tapd117's Avatar
We had to take them off my sons 05 Mustang GT as Razzi did a terrible job of matching the Sonic Blue Paint, out body shop just used some 3M double sided tape from Wal-Mart it will have a red outer cover, cut to size and apply, we didn't use the excellerator.
I would call Razzie or e-mail their customer service and ask for them to send you some new tape. We repainted both window scoops and reapplied no big deal........ Just a note remember to clean glass and the scoops with alcohol to get any dirt off before applying tape, good luck!
Old Feb 19, 2006 | 07:23 AM
drno's Avatar
tapd117--what did you use to remove the scoop?
Old Feb 19, 2006 | 07:49 PM
tapd117's Avatar
<div class='quotetop'>QUOTE(drno @ February 19, 2006, 8:26 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
The body shop just eased it off with a sharp scraping blade, it was no big deal, did you give any thought to contacting Razzie direct and see if they would send a new set of tape. As I recall these were expensive, I don't particularly like them as my 05 is more of a retro, but my teenager wan't them on his 05 and we ordered off ebay.
Let me know how you get this worked out. Just take your time and don't get in a hurry, I would do it with them warmed up with a blow dryer and there are many posts with members using fishing line.
We haven't had any problems with fresh tape, again I would advise against the promoter enhancer product, just my thoughts......
Old Feb 20, 2006 | 07:10 AM
drno's Avatar
thanks for the info-i did contact razzi and they are sending more tape. i had no intention of using the adhesion promotor- this was a suggestion from the place i bought the scoops and i felt they didn't have a clue as to what to do
Old Feb 20, 2006 | 07:21 AM
tapd117's Avatar
<div class='quotetop'>QUOTE(drno @ February 20, 2006, 8:13 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
The adhesion promotor would have eaten into your plastic, I skipped it on my CDC Interior upgrade kit after talking to the company that makes it, if you use one of the by products of the extra adhesion is your plastic gets messed up.....
Good luck glad everthing worked out, a big company like Razzie is going to take care of their customers..
GG
Old Feb 26, 2006 | 06:48 AM
drno's Avatar
well, the scoops came off very easily with a narrow flexable scraper and the old tape was east to remove. however , applying the new tape is a real pain in the butt -getting it to lie flat around the curves. perhaps i am being too **** but i don't want to do it again
iliveonnitro
Oct 7, 2021 06:31 PM
kponypower
Jun 17, 2020 07:17 AM
TerryD
Sep 28, 2015 11:48 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
