zex kits again
![Question](https://themustangsource.com/forums/images/icons/icon5.gif)
I was looking at the bama chips set up. Do you need a heater to keep the pressure stable. I found out that the temp of a bottle needs to be near 90 degrees to propery work and give you the HP you need.
I bought the same set up from Bamachips as your looking at. I love the kit but I find the bottle warmer won't heat the bottle up enough. I im going to buy a new blanket once I find a review on a good one.
I will. What I am fiding is a blanket is going to cost about a hundred dollars and I just spent my mod money for this month. Looks like I will be sprayless for another month.
Bottle heater
I had the complete ZEX system on my old car and the heater sucks...I went to the junk yard found an old caddy,any car with heated seats will do,and made my own heater for 10 bucks.I did buy a time relay for the heater and after trial and error I found if I set the timer for 15 minutes my bottle would be 1000psi or so.I know this was kind of a ghetto set up ,but it worked great and I had all of 14.99,with switch and heater in it,that was better than my 150 dollar zex heater.
9/16/15 06:44 PM
