Whpple high output fuel injector question
Old Dec 24, 2007 | 03:05 PM
OKLACOP's Avatar
I finally pulled the trigger on a Whipple intercooler upgrade kit for my non intercooled Whipple. My original low output kit came with 32 pound injectors. My understanding is the 32 pounders are good for 360-370 rwhp. Thats about where my car is now. Ive been reading the "Project Milf" series of articles in MMFF, in particular Oct. 2007 issue, pages 182-194. When they added the intercooler they also added 48 pound injectors (the same as the GT500 injectors). These are good for 500-550 rwhp.
Should I go with the 48lb injectors.......I'm thinking yes. I'm also upgrading to a 12lb pulley instead of the 10lb pulley coming in the kit. Keep in mind I have an auto, so I can't go completely crazy. What do ya'll think?
I realize I misspelled Whipple in my title.........Sorry for being a dumba$$
Old Dec 24, 2007 | 03:09 PM
turbo05gt's Avatar
They say they are 48 but flow more like 50-52's, yes get them I think I have some used 55's if you want those.
Old Dec 24, 2007 | 03:20 PM
anthony05gt's Avatar
Kevin MacDonald (Diablosport) told me when I ordered my kit to definitely get the 48's or 52's. I ordered the 52's. He said there's about 10 good reasons to have them even though 39's will work at 10 psi.
Old Dec 25, 2007 | 10:39 AM
bob's Avatar
bob
The FRPP catalog has some nice articles on fuel injectors (among other intersting tidbits) http://www.fordracingparts.com/downl...gs/2008-pp.pdf pages 137 to 140 deal specifically with injector requirements.
Old Dec 25, 2007 | 06:11 PM
TASSY5's Avatar
The WHIPPLE HO. comes with 39 lbs injectors. not 48 or 52's.
Are they not sufficient???????????
Old Dec 25, 2007 | 06:59 PM
Torrence's Avatar
Your going with a 12lb pulley??? I hope you have some good brakes, your gonna need them...
Old Dec 25, 2007 | 07:05 PM
ramairgt1's Avatar
The H.O. kit actually comes with 38lb injectors
Old Dec 25, 2007 | 08:28 PM
TASSY5's Avatar
OK THEN, you didn't answer the question?
Are they sufficient for 10 #' s of boost
Old Dec 26, 2007 | 05:15 AM
turbo05gt's Avatar
Yes you can, Im running 39's with 10lbs, but Im also now looking to get 60's.
Old Dec 26, 2007 | 06:23 AM
ramairgt1's Avatar
Whipple wouldnt have put them with their HO kit if they didnt think so
Old Dec 26, 2007 | 08:24 AM
Here's the deal. The supplied injectors are sufficient for 10 lbs, but the fuel system works much harder than need be. Also, if you raise the boost later you'll have the fuel flow if you go with 48' or 52's. This came straight from Kevin MacDonald who's a top S-197 tuner.
Old Dec 26, 2007 | 03:00 PM
killbee's Avatar
I'll be getting my system, shortly and I think I will be going with the 60lb units. That way the fuel system will work less and I will have room to grow when I build the stroker later on. I have seen several dynos where the 38lb's are running at 98% at 10lbs of boost. I'm not saying this is unsafe but pretty well maxed between 400hp and 450hp. 60lb injectors were usually running between the 35% and 50% cycle rate between 450hp and 500hp at the wheels. Every car will be diffrent so need more some will be ok, all depends on the mods. If you plan to go with more hp later get a bigger injector and tune for that but get it on the dyno with a good tuner no matter what you go with.
NC14GT
Feb 20, 2023 09:42 AM
Mpaps
Oct 11, 2017 08:06 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
Sep 8, 2015 10:45 AM
