When is it time to re-grease poly bushings?
Old Jun 11, 2007 | 08:14 PM
Jon_Purdy's Avatar
When is it time to re-grease poly bushings? Also, while I have your attention, please describe what would be considered "normal" noise when using poly bushings in the lca's, uca, anti-roll bars, and panhard bar.
Thanks in advance,
Jon
Old Jun 12, 2007 | 07:44 AM
MooStang05gt's Avatar
Jon... it's difficult to describe what normal poly bushing noise is.. I live a 1/4 mile down a dirt road that becomes a washboard surface regularly.. You will be able to hear noise as the control arms and panhard bar move up and down. But, you shouldn't hear any snapping or popping from the suspension. I hear a low, dull sounding noise as the suspension move.
As far as greasing the bushings, I have mine done every time I do an oil change.. if they get dry you will know it, they tend to squeak a lot or your noise will get much louder. If you live where it rains a lot you might consider using a marine grease instead of a regular or synthetic chassis grease.
Bobby M.
Old Jun 12, 2007 | 11:16 AM
Speeddmn's Avatar
Bobby M.
Simple as that every oil change and depends on climate. Normal noise should be the minute stiffnes noise, like a knock of to rubber mallets. But depends on when you lubed them last also.
Old Jun 12, 2007 | 07:31 PM
RobK's Avatar
As mentioned, do it as part of your routine maintenance or...if they squeak then grease them.
FromZto5
Aug 24, 2015 09:02 AM
Mackitude
Aug 17, 2015 04:14 PM
Jul 30, 2015 06:47 AM
Rog13GTCS
Jul 19, 2015 02:46 PM
