When/how do I replace/clean my C&L filter?
Old Apr 22, 2008 | 09:59 PM
jmanpatsfan's Avatar
When do I need to replace my C&L filter? Can i just clean it instead? If so, what is the best method of cleaning it?
Old Apr 22, 2008 | 10:28 PM
atomic_il's Avatar
I had mine on for three years and cleaned it once, it hasn't been red in god knows how long... last week i went and got a spectre brand intake from autozone and that is working fine. The car feels much peppier now!
Old Apr 23, 2008 | 02:23 AM
MTAS's Avatar
Thumbs up
Spray the inside and outside with Simple Green, rinse with a hose (you'll be amazed at the dirt that comes out of it), let it dry (I just set it in the driveway and let the sun dry it), lightly re-oil it, go tear up the roads
Old Apr 23, 2008 | 06:04 AM
tw0scoops123's Avatar
K&N makes a cleaning kit which I used.
Old Apr 23, 2008 | 07:14 AM
05fordgt's Avatar
+1. Their kit is great! Comes with all you need (including the oil).
Old Apr 23, 2008 | 09:16 AM
when should I clean it? I have had it on for about 4 months now.
Old Apr 23, 2008 | 02:38 PM
jaegerbros's Avatar
I just cleaned mine for the first time in 40k miles and it wasn't very dirty i just wanted it to look nice and red again, i used the K&N kit, if you live in an especially dusty or dirty area you might do it sooner.
Old Apr 23, 2008 | 03:48 PM
Speeddmn's Avatar
i do mine every oil change.
Old Apr 23, 2008 | 08:15 PM
Boltzman's Avatar
if you do the simple green method,what type of oil and how much does "lightly" mean?Thanks
Old Apr 26, 2008 | 06:44 AM
Mach's Avatar
+1
I think the simple green method sounds good as well. I have only 10K on it but do live on a gravel road so it would look much better if cleaned prior to shows this summer.
Is there a "spray" type oil that would work? I would think it would provide more even coverage.
Somebody please share your wisdom...
I take it the K&N Filter kit is this one? http://www.knfilters.com/search/prod...x?Prod=99-5000
How many cleanings will the kit provide? (a guess from those who have used it is fine)
Old Apr 26, 2008 | 06:48 AM
Stoenr's Avatar
I picked up the S&B kit, same thing as the K&N I think.
I do mine once a year. Everyone will not need it done at the same time. The kits come with instructions.
Old Apr 26, 2008 | 08:46 AM
JimC's Avatar
legacy Tms Member
Originally Posted by Mach
+1
That's the kit I bought. I've used it 4 times now and still have plenty more uses I believe judging from the weight of the cannisters. The oil is a spray can like a "rattle can paint" - it can be easy to over oil, I use the seam of the filter as a starting point so I know when I have gone around once.
Old Apr 26, 2008 | 07:42 PM
Boltzman's Avatar
Dustin said that he's over oiled before and it caused problems. Thats why I ask
Old Apr 27, 2008 | 07:10 PM
Speeddmn's Avatar
yes you can over oil it. Just a good even coat. if it drips off the filter its to much.
I also always lay/sit mine in the sun for an hour or so before I install it.
Old Apr 27, 2008 | 07:34 PM
Boltzman's Avatar
thanks
Old Apr 28, 2008 | 10:18 AM
Rash's Avatar
Or you could replace it with a dry one - no more oiling: http://www.amsoil.com/StoreFront/eaau.aspx
Old Apr 28, 2008 | 04:22 PM
Boltzman's Avatar
Not diggin that blue..I wonder if they come in red
NC14GT
Feb 20, 2023 09:42 AM
MustangConvert11
Sep 30, 2015 08:01 PM
southern stang
Sep 26, 2015 04:19 PM
TripleBlack14
Sep 17, 2015 07:48 AM
