What's Needed To Install Crate Engine?
Old Jan 30, 2005 | 05:42 PM
Stangfriik's Avatar
Just for sheets and giggles, what would be needed if you wanted to add say the cammer or the big daddy 514cu engine ford racing has that puts out a whopping 625hp? Anything like a new tranny, etc?
Old Jan 30, 2005 | 06:34 PM
TURBO 05's Avatar
new computer (cammer uses a different comp.) and thats about it for the cammer.
THe 514.... well the list of changes you would have to make is to long so we'll not worry about that
Old Jan 31, 2005 | 02:47 PM
b_btrick's Avatar
here ya go, should be just what u r looking for ...
http://www.fordracingparts.com/download/enginetips.asp
Old Feb 1, 2005 | 01:01 PM
clintoris's Avatar
you're also going to have to pay attention to the rest of the drive line. the stock tranny won't handle that kind of HP very long. You're going to need something beefier... like a T-56 6 speed that is built for 500+ hp.... like the one out of the Viper. .... just get the right bell housing and you're good to go.... I haven't looked but Ford Racing might even have it in the catalog. The stock tranny probably won't hold much more than 450 hp or so.
You're going to need a new driveshaft and yolks and heavier u-joints. You're rear end will probably not hold up either... I think stock, they'll only hold about 500hp. You'll have to look into a beefier locker and axles. Then you're going to want to reinforce your body with sub fram connectors and such because there's going to be a lot of twisting. I know this chasis is a lot stiffer than the previous generations, but I don't know how many test mules had 625HP.
Not to rain on your parade, brutha.... but have fun with it... it's going to be big $$$
You can probably get away with just an engine swap for a while, but dropping the hammer on the rest of the drive line will make it go belly up in short order....
Good times, though..... a man after my own heart.... you can never have too much hp.
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
bigaaron
1994-2004 V-8
Aug 22, 2015 12:06 PM
roushcollection
Jul 28, 2015 02:08 PM
goocher625
1994-2004 V-8
Jul 15, 2015 08:08 AM
