What should your A/F look like on a dyno run?
Old Jan 16, 2006 | 11:47 PM
jvm051's Avatar
If I could figure out how to post the image of the A/F range, I'd do it. I may scan it later, but at the start of the run, from 2000 RPM to about 3250 my A/F is between 14.8 and 14.9. Then the rest of the way it drops from around 12.23-12.8. The guys at the dyno shop said this was a safe range to be in. Other peoples dyno charts show their starting #'s lower, but higher later on in the RPM range.
Old Jan 17, 2006 | 04:01 AM
stkdidy's Avatar
mine was erradic from 12.2 to 14.4 before tune, and is dead flat at 12.9 from 2750 to 6300 after the dyno tune.
the reason for the erradic behavior was puttin on a ginormous JLT intake and not telling the computer.
btw, a/f is usually much higher in the early rpms, then should level out somewhere between 12 and 13.x by the time the power band kicks in
Old Jan 17, 2006 | 08:46 AM
05-1947's Avatar
regardless of rpm at wot your a/f should be somewhere between 12.5-13.0.
Old Jan 17, 2006 | 01:21 PM
SixtySix's Avatar
Jon's is even more ginormous...98mm without that venturi in.
Road_Runner
Sep 2, 2024 04:46 PM
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 30, 2015 07:02 PM
