went up a WS6 this morning and
Old Jan 28, 2006 | 07:03 PM
elvism's Avatar
ran into a problem.
it was about 8:30 this morning. it was cold and i see that the ground had residue of rock salt from a couple days ago. the ground was also cold from the low temp outside.anyway my concern was getting traction in these condition. a few weeks ago i remember flooring the gas and it being cold outside early in the morning and the car fish tailed like crazy. anyway getting back to the race w/ the WS6 the light turned green and i floored it and my car just completely burned rubber and
fish tailed sideways.
i noticed right before the light turned green that the WS6 started to
roll a little bit and he didnt spin. by the time i got out of the hole it was too late. the question i have if i start a race with traction control and when i get up to say 4000 and i turn it off will that make a difference? i was really hoping for a close race. with my new tune i should be in 13.3-13.4 range.
Old Jan 28, 2006 | 07:30 PM
adrenalin's Avatar
your problem is you floored it and dumped the clutch. Next time get your rpms up around the 2300 mark then let out the clutch, then floor it. At least that's my guess. On another note, why were you street racing in the first place? Save it for the track.
Old Jan 28, 2006 | 07:43 PM
ManEHawke's Avatar
It would have been an extremely close race if he was stock.
Old Jan 28, 2006 | 08:21 PM
SONICBOOST's Avatar
Does traction control slow you down in a race?
Old Jan 28, 2006 | 08:31 PM
Dysan's Avatar
He's got an auto....no clutch involved...
Old Jan 28, 2006 | 08:33 PM
SONICBOOST's Avatar
Is that ^ to me
Old Jan 28, 2006 | 09:35 PM
nicksolheim's Avatar
Traction control takes power away from the rear wheels when they loose traction.
Yes! It will slow you down if you jump on it enought to brake em free. This is espicially common when running the 1/4 or racing from a stop, not only will the cars ECU take power away on the launch it will also take it away as you work through the first 3 gears, that is if you are able to bark your tires while shifting through them.
NO! If you start a race from a higher speed, say a 50mph+ roll, it really wouldn't matter if traction control is on or not. At that speed if you floor it chances are you won't brake your tires free.
Old Jan 28, 2006 | 10:49 PM
eighty6gt's Avatar
If you're going to race stoplight to stoplight, shut the TCS off and control traction yourself.
Ford TCS is meant for "oh darn" situations, not as a launch control.
Old Jan 28, 2006 | 10:52 PM
Hatchman's Avatar
I've noticed, if pedal is floored, TCS won't kick in. I guess the car figures you want to spin/slide.
Old Jan 28, 2006 | 11:06 PM
atomic_il's Avatar
Originally posted by elvism@January 28, 2006, 10:06 PM
ran into a problem.
um i have a question for you... in your sig it says this:
5/27/05 had my JLT kit installed w/ better tune from JDM
new dyno #'sW/O SPACER 293hp/315 tq
1/4 mile --?
12/13/05 - w/ spacer 290hp/310tq- even better tune
now how do those numbers make sense... WITH the spacer and better tune you made LESS power? am i reading this right?
Old Jan 29, 2006 | 01:04 AM
Enfynet's Avatar
It would appear he removed the TB spacer when he got re-tuned.
Old Jan 29, 2006 | 11:07 AM
atomic_il's Avatar
but it says WITH tbs... depends what kind i guess. If it's the MMR one, then i could see how it would make less, but the Jet one has been known to up the torque a bit
Old Jan 29, 2006 | 01:23 PM
srichard's Avatar
I eat SS Camero's and WS6's for lunch all the time. Really though, it's usually pretty close but I tend to pull on them pretty hard in third... that's if they are stock, as for all the highly modded cars running around here; I don't even mess with them.
Yeah, you just got a bad launch, you would have took him if you launched good. Turn the TC off, launch about 2200rpm and feather it till your getting a good hook up, then mash the hammer. Bye Bye WS6! Of course it's different for every car but it works for me.
Not that I promote any kind of street racing. :nono:
Old Jan 29, 2006 | 01:37 PM
SixtySix's Avatar
And not to mention the fact the conditions... I just wouldn't bother with even the tameest stoplight romp in those conditions (cold, poor traction, etc...) But that's just me
Old Jan 29, 2006 | 03:05 PM
GRAYPNY's Avatar
That's not something that you have to even think about in AZ is it Tony?
Old Jan 29, 2006 | 03:33 PM
korinwoodo's Avatar
You went up a WS6 this morning? That must have been paintful.
Old Jan 29, 2006 | 06:00 PM
blackened's Avatar
lol ^
Old Jan 29, 2006 | 06:42 PM
elvism's Avatar
1/4 mile --?
the reason i guess the the hp/tq were down from before was probably it was freezing outside and they had the heaters in the garage so they wouldnt freeze there a-----. the door to the garage was 1/2 way open. the new tune is for sure better then before even though the #'s are down slighty.
Old Jan 29, 2006 | 07:48 PM
SixtySix's Avatar
Hey, it gets cold here at night... And don't forget most of the state is in the mountains
unnoticedtrails
Jul 17, 2017 11:10 AM
Fedupdave42169
Oct 20, 2015 10:29 PM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
DarrenGT
Aug 28, 2015 10:01 AM
