Torquing the struts (D-specs) on the car?
Old Oct 14, 2009 | 11:47 PM
OhSevenGT's Avatar
Hey all. I just installed Tokico D-Specs and FRPP springs. After about 50 miles I started getting a noise going over bumps. Turns out the nut on the strut was loose enough to spin by hand. Is there a way to torque that thing on the car or do I have to remove the whole assembly and do it over? I have to hold the top portion with like an 8mm so it wont spin. Anyone have this problem?
Old Oct 15, 2009 | 10:52 AM
chabbz182's Avatar
Yeah you just have to take 2 wrenches and tighten the crap out of it. Also did you change the strut mount?
chabbz182's Avatar
you can torque it on the car you don't have to take the assembly out.
Old Oct 15, 2009 | 11:26 AM
OhSevenGT's Avatar
Yeah I changed the strut mounts out to the GT500 ones. Another reason that I dont want to remove the assembly. So what do you use like a crows feet or something?
Old Oct 15, 2009 | 12:18 PM
GottaHaveIt's Avatar
Question is changing the strut mounts a pita ? I have a brand new set for GT 500 that I'd like to drop in so I'm hoping all I need is a spring compressor ? any ideas appreciated.
Old Oct 15, 2009 | 12:20 PM
OhSevenGT's Avatar
you just need a spring compressor and some tools. its pretty easy to drop the assembly. I just followed the link that Taco bill wrote up. Just be sure to torque the struts down correctly before you re-install the assembly.
Old Oct 15, 2009 | 12:35 PM
I'll have to go looky at Bill's didn't know it was there dah of any place I could have should have looked ! I like his Chuck Norris approach to anything !
Old Oct 15, 2009 | 12:47 PM
CO_VaporGT_09's Avatar
You basically have to use two separate open ended wrenches to torque the strut nuts, or the swaybar endlinks for that matter. One to hold the central shaft from moving, the other to tighten the big nut. Those 8mm open ended wrenches ain't that big, though, hard to put much torque through them.
Problem is that it makes it difficult to know what the actual ft-lbs it's torqued to. The endlinks no big deal, just tighten til you can't anymore. But the struts are supposed to be like 50 or so if I remember, and the D-specs in particular strongly caution not overtightening them. I just gave it my best guess and it seems fine so far. Still though, how would you go about getting a socket on that large nut without the inner shaft rotating as well?
Old Oct 15, 2009 | 12:58 PM
Bus driver from South Park lol sorry.
Old Oct 15, 2009 | 01:11 PM
OhSevenGT's Avatar
the plan right now is to have someone hold the 8mm wrench and then I use a crows feet on the center nut to torque it down. The angle is sharp so Im not sure if I will have enough leverage. I'm sure they recommend removing the assembly.
Old Oct 15, 2009 | 01:20 PM
you could wrap a rope around and then twist it that'll get a bite on the shaft ?
Old Oct 15, 2009 | 01:46 PM
My wrenches are angled for the box end, so I was able to put that on the strut nut, but only get maybe 45 degree rotation before hitting one of the studs that hold the shock up in the tower. I think I managed to get it torqued well enough using the small 8mm boxed end as well above the larger wrench, but still don't know what the actual number is.
Old Oct 19, 2009 | 08:30 PM
NastyStang113's Avatar
The crows foot will work.
Old Oct 19, 2009 | 08:34 PM
OhSevenGT's Avatar
got em both torqued. Passanger side was easy and clicked right away. Drivers side wouldnt so I ended up backing the nut all the way to finger loose. Then I tightened with end wrench. Started the torque wrench at 30-clicked. then 40-clicked. at this point I went up 2 ft pounds at a time until I hit 48. I had to go slow precise but I got it torqued to spec this way. No crows feet necessary.
Old Oct 19, 2009 | 09:16 PM
Maybe I'm a dumb ***, but what exactly is a crows feet (foot)??
Old Oct 19, 2009 | 11:22 PM
OhSevenGT's Avatar
its basically the open end of the wrench was cut off. It has a square hole for the ratchet drive or extension. Kind of like wrenching from the top with a ratchet.
heres a pic
http://images.google.com/images?hl=e...-8&sa=N&tab=wi
Old Oct 20, 2009 | 06:38 PM
itchy's Avatar
Just an FYI, I am sure most people already know this ...
but in case you didn't, if you use a crows foot attachment you will need to calculate the torque based on the new lever arm.
Old Oct 26, 2009 | 05:11 PM
Mojave Dave's Avatar
This may seem obvious, but some blue locktite will end your problems. It did mine.
Old Oct 26, 2009 | 09:28 PM
Blue locktite will eliminate reinstalling removed struts and torqueing them down for the first time?? Love to see that...
Maybe it'll keep them from loosening over time...
Old Oct 27, 2009 | 02:36 AM
Cavero's Avatar
Locktite will keep it from loosening back up. According to Ford's specs, it should be torqued down to 62Nm, or 46 ft-lbs.
I had this happen to me. I used an 8mm open ended wrench on the flat part of the strut rod and then a crow's foot on the nut. Just be CAREFUL. if you put too much torque on the strut, you can crack the rod, and that'd be bad. very bad.
Ecostang
Nov 3, 2022 08:50 PM
Mackitude
Aug 13, 2015 01:05 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
Ecoboost
Jul 25, 2015 06:32 PM
Ecostang
Jul 11, 2015 09:06 AM
