Tire Pressure Warning Monitor Fault?
It seems as though every time I turn on my car it says "TIRE PRESSURE. MONITOR FAULT" and it will stay on until I push reset. Is this normal? Or should I seriously consider checking my tire pressure?
If I were you, I'd find a way to remove that ****. You can buy your own tire pressure monitoring system for $.99. It's called a trie pressure checker.
It means that your pressure monitor is bad. If your tires would have been low you would have gotten a "LOW TIRE PRESSURE" warning instead. I think you should have the dealer look at it.
There are 3 different warnings related to TPMS.
LOW TIRE PRESSURE.
Originally Posted by From page 69 of the 2007 Owners Manual
LOW TIRE PRESSURE.
Displayed when one or more tires on your
vehicle have low tire pressure. Refer to Inflating Your Tires in the
Tires, Wheels and Loading
chapter.
TIRE PRESSURE MONITOR FAULT.
Displayed when the Tire
Pressure Monitoring System is malfunctioning. If the warning stays
continues to come on, have the system inspected by your authorized
dealer.
TIRE PRESSURE SENSOR FAULT.
dealer.
Displayed when a tire pressure
sensor is malfunctioning, or your spare tire is in use. For more
information on how the system operates under these conditions,
Understanding Your Tire Pressure Monitoring System
in the Tires,
Wheels and Loading chapter. If the warning stays on or continues
come on, have the system inspected by your authorized dealer
Gigantor
5/11/23 07:31 PM
