Tire Pressure Warning Monitor Fault?
Old Jan 26, 2007 | 08:35 PM
n00bstang's Avatar
It seems as though every time I turn on my car it says "TIRE PRESSURE. MONITOR FAULT" and it will stay on until I push reset. Is this normal? Or should I seriously consider checking my tire pressure?
Old Jan 26, 2007 | 08:37 PM
sound wave's Avatar
that is not normal. i would think it would be smart to check your tire pressure. only would take you a few seconds.
Old Jan 26, 2007 | 08:50 PM
SteelTownStang's Avatar
Definitely not normal... check your tire pressure.
Old Jan 26, 2007 | 09:11 PM
Cobrakev's Avatar
Have you changed your wheels at all?
Old Jan 26, 2007 | 09:29 PM
sound wave's Avatar
good point
Old Jan 27, 2007 | 01:49 AM
n00bstang's Avatar
nope. stock to the bone. i'm going to check tire pressure tommorow.
Old Jan 27, 2007 | 02:49 AM
Mustangfreak's Avatar
If I were you, I'd find a way to remove that ****. You can buy your own tire pressure monitoring system for $.99. It's called a trie pressure checker.
Old Jan 27, 2007 | 03:03 PM
n00bstang's Avatar
I checked the tire pressure today, 30 on all tires. below the recommended 32, so I filled it up. But the warning stll comes up. Should I take it to the dealer?
Old Jan 27, 2007 | 03:36 PM
neil07gt's Avatar
It means that your pressure monitor is bad. If your tires would have been low you would have gotten a "LOW TIRE PRESSURE" warning instead. I think you should have the dealer look at it.
There are 3 different warnings related to TPMS.
Originally Posted by From page 69 of the 2007 Owners Manual
LOW TIRE PRESSURE.
Displayed when one or more tires on your
vehicle have low tire pressure. Refer to Inflating Your Tires in the
Tires, Wheels and Loading
chapter.
TIRE PRESSURE MONITOR FAULT.
Displayed when the Tire
Pressure Monitoring System is malfunctioning. If the warning stays
continues to come on, have the system inspected by your authorized
dealer.
TIRE PRESSURE SENSOR FAULT.
Displayed when a tire pressure
sensor is malfunctioning, or your spare tire is in use. For more
information on how the system operates under these conditions,
Understanding Your Tire Pressure Monitoring System
in the Tires,
Wheels and Loading chapter. If the warning stays on or continues
come on, have the system inspected by your authorized dealer
Gigantor
May 11, 2023 07:31 PM
kponypower
Jun 17, 2020 07:17 AM
cozyp828
Apr 18, 2016 09:46 PM
