tire has a leak? what's the best procedure?
So my driver rear tire has a pretty good leak in it. I'm not sure where on the tire the leak is, or what caused it. Don't see any gashes or nails in it anywhere.
I came out to day to take my car for a spin and noticed the RR it looked kind of low. It had only 12 lbs of air in it. Checked all the others, they were at a solid 40lbs. I aired the RR up to 40 lbs, checked it again after 30 minutes or so, and it had gone down to about 32lbs.
Anyway, with the rate of this leak, if I can find a tire place that is close (within 2 miles or so), would it be safe to drive it there right after I air it up to 40lbs? Or would it be best to slap the donut spare tire on there and drive the car to a tire place with the donut on the wheel? (never driven a car on the spare before)
DON'T FOLLOW THE PRESSURE RATINGS ON THE TIRES THEMSELVES...EVER!!!!! Follow the ratings on the sticker in the door jamb. The ratings on the sidewall are the maximum pressures for seating the beads only.
Thanks, I'll do that next time What if the tires are different than the factory tires, wouldn't they have their own rating? That seems very stupid for them to put incorrect pressure ratings on the tires. I haven't notice any side or center wearing, just nice even wear.
What do you guys set your pressure to?
If the tires are the same size as the factory tires, even though they are a different brand, you should stick with the recommended pressure on the door jam. If they are bigger tires, you will need to take the pressure down a few pounds I believe. Maybe a more knowledgable tire expert can chime in here though.
I think the leak is getting worse (hard to tell, I'll check again to night) Tomorrow I'm taking the car in. If the leak is alot worse, is it ok to put the spare tire on the rear? I had heard from somewhere that putting the spare tire on the rear is not good for the differential and things in there. Is this true? I'll be driving 1.5 miles :-)
FWIW, one of my slicks would lose a lot of air over the course of a week or so sitting in the garage. When I had the last set mounted, I asked them to replace the valve stem... and it solved the problem.
You don't have to type in caps
Regarding your air leak, if you absolutely can't find a puncture then pick up a valve stem wrench and try to tighten the core of the Schraeder valve. That my be the culprit. If it is a puncture, have it dismounted and patched - no plugs. If the puncture is within an inch of the sidewall then it's time for a new tire.
Discount tire offers free tire repair (if there's one near you). I've had 3 leaks fixed there over the last year. One we couldn't find the first couple of times, but all were patched from the inside (plugs are bad).
It's amazing how many people go by the rating on the sidewall of the tire, I've shown many here at work the stickers in their door jams, they were all clueless to it.
Good luck with your tire.
yea, the door jam, that's not the place I would expect to find the tire info! I know now, thanks guys!
Yes, Discount Tire is where i used to go in phoenix (I had a puncture), I was amazed that they did it for free, and I had never purchased anything from them (either before, or after). nice service that they offer :-)
what is the difference there? i assume a plug is quicker and cheaper? (maybe not as strong?)
A plug is just some rubber and glue stuffed into the hole form the outside, and can either leak again or come out. A patch is done from inside the tire, and covers the hole and area around it (it's also glued on) but with the size and the pressure inside the tire, it's far less likely to come off or leak.
