Sylvania SilverStar bulbs
#82
It shouldn't cause the bulbs to burn out sooner since it will be feeding nearly 100% of the voltage coming from the alternator and batteries, rather than losing some power through the stock wiring and PCB leads.
AFAIK, the low-beams are the only ones not fed through relays. Ford in its infinite wisdom decided to use the SJB to feed power to the low-beams.
Diode Dynamics
6/12/18 03:26 PM
Diode Dynamics
2/28/18 09:37 AM
tacbear
Off-Topic Chatter
8/19/15 09:05 AM
