Anybody Remember How to Remove
Old Apr 27, 2007 | 09:59 PM
WuTimeUT's Avatar
the over the axle pipes without the use of a lift??? I have a jack and jack stands and I'm about to switch them out. I thought I remembered seeing a write up on it. ??
Old Apr 27, 2007 | 10:12 PM
Fman67's Avatar
Over axle pipes install/removal
Hello...i have done this...you have to jack up car as high as you can,and support car with a good set of jackstands...at body jacking points. Then i supported axle with a floor jack. You will need to dissconnect rear sway bar links at body...Then lower axle as far as it will go. Then just loosen up clamps at midpipe and snake them out. Aftermarket pipes go in and out much easier than stockers do...due to less bends.Hope this helps out.
Old Apr 27, 2007 | 10:23 PM
WuTimeUT's Avatar
I think that makes sense. What are the jacking points? I always put the jack stands on the axel.
Old Apr 28, 2007 | 06:19 AM
tom281's Avatar
I did what he said, although I didn't have to remove the sway bar links. All I did was jack the car up, support it with jackstands (I use the front mounting area for the LCA's) and remove the jack, letting the wheels extend all the way down as far as they'll go. That gave me enough room to get the stockers out and the Borlas in.
Old Apr 28, 2007 | 05:10 PM
Here's where I always place my jack stands.
Old Apr 28, 2007 | 06:28 PM
tom281's Avatar
Hey Bill, you're supposed to place the jackstands on a level surface!!!
Better replace that missing floor tile!
Old Apr 28, 2007 | 08:48 PM
I'm waiting for all of them to go, then I can go for the black and white checkered floor!
Old Apr 28, 2007 | 10:32 PM
karman's Avatar
Originally Posted by TacoBill
gh
You can start any time, I think there are enough missing already to start the pattern.
Old Apr 30, 2007 | 07:32 AM
Man, that's messed up, Karman!
NC14GT
2007-2009 Mustang GT/CS
Sep 27, 2015 03:03 PM
Mustang65bob
Sep 21, 2015 11:30 AM
jim010
Sep 14, 2015 10:15 PM
Sep 10, 2015 12:44 PM
