Steeda UDP install help.
Old Jan 6, 2010 | 11:06 PM
j0eyabs's Avatar
I have three questions.
1.Does anyone still have their instructions from Steeda that they can scan to me?
2.Is it possible to remove the crank pulley without a gear puller?
3. I bought these used and it doesnt have the shorter alternator bolt. Where can I get one?
Old Jan 6, 2010 | 11:51 PM
Casey4s's Avatar
(1) Steeda has the instructions posted on their web page as I remember. EDIT I just looked and they are NOT there, sorry and I don't have mine any more either.
(2) NO. You can usually rent a puller from a parts store, but they really don't cost all that much for a basic one. Did you get the LONGER crank bolt to install the new pulley with your purchase? If not you either need a longer bolt to pull the pulley onto the crank or rent an installer tool.
(3) I would pull out the factory existing bolt and cut the protruding threaded part off or take it to NAPA and have them match it up with what you need.
You should also replace the crank bolt any time you remove it. The FORD part number is F5RZ-6A34Q-B it cost about $7 from your Ford dealer.
Do not use an impact to install the pulley BTW, and you shouldn't have to FORCE anything. This is a really easy install. Taco Bill has a write up on this install here on this forum.
Old Jan 7, 2010 | 05:09 AM
1fastbob's Avatar
I have an uninstalled set of Steeda UDPs in the garage. I will look for the instructions when I get home from work and scan them to you if this will help.
Bob
Old Jan 7, 2010 | 06:12 AM
NJ3's Avatar
NJ3
Below is the link to TacoBill's install.
https://themustangsource.com/showthread.php?t=452799
Old Jan 7, 2010 | 08:45 AM
MaverickMLFD371's Avatar
call up steeda! they will glady send you a new set of bolts (including the bolt to get the pulley on) for like $2 and email you the instructions.
Old Jan 7, 2010 | 12:11 PM
j0eyabs's Avatar
STeeda wants over $20 for the new bolt.
Old Jan 12, 2010 | 05:57 AM
must be the new management at work with the jump in price.
Sep 1, 2015 01:19 PM
dakotawolfe
Aug 26, 2015 04:01 PM
ustabawannab
Aug 5, 2015 08:32 PM
Jul 30, 2015 06:47 AM
Ecoboost
Jul 25, 2015 06:32 PM
