Skipping a beat on startup
Old May 15, 2008 | 10:07 AM
jmanpatsfan's Avatar
Whenever I start the car for the fist time in morning, it never starts up smoothly, like it skipping a beat when cranking. But if I start it up within a few hours of turning it off, it starts fine. Normal?
Old May 15, 2008 | 10:19 AM
jwooski's Avatar
try to disconnect the battery for 3 min then reconnect the ground and try it again let me know what happens
Old May 15, 2008 | 10:54 AM
adrenalin's Avatar
Hard to say, especially since you have added some mods.
Old May 15, 2008 | 11:18 AM
jwooski's Avatar
by disconnecting the batter it resets the kam in the pcm allowing your car to relearn with all your mods unless your mods are too drastic for the pcm
Old May 15, 2008 | 11:27 AM
i believe it did that before the CAI as well, but I will try to disconnect the battery.
Old May 15, 2008 | 11:34 AM
jwooski's Avatar
how did that work out for you if not what is your vin # i can run oasis on you rcar for tsb or ssm on your car
Old May 15, 2008 | 11:51 AM
theedge67's Avatar
Mine does that too, not a big deal. I think it is fairly normal, and I don't see any harm coming from it. Mine has been doing that for the past 45K miles or so...no harm yet.
Old May 15, 2008 | 12:20 PM
jwooski's Avatar
you could possibly have an injector leak down problem when sitting for hours after cooldown
09-gt/cs
Oct 15, 2015 10:03 AM
AdPock
Sep 22, 2015 05:55 PM
JonathonK
Which is Better
Aug 30, 2015 06:14 AM
HMR-TYM
Jul 31, 2015 10:39 AM
