Silver Foil under master cylinder
Old Sep 25, 2005 | 09:50 PM
DanteMO's Avatar
All,
I was running some fog lights and have 2 questions:
I was under the drivers side dash and I saw a fuel reset button. What is it for? Googled it and found a bunch of hits on how to replace it, but doesn't say what it does? Is this a fuel cutoff switch in case the car flips and that button resets the switch?
and what is that silver foil panel right next to the master cylinder. Under the dash it's got a foam cutout?
Thanx in advance..
Old Sep 25, 2005 | 11:09 PM
tom_vilsack's Avatar
silver foil maybe for some type heat protection?...(in my old dodge shadow i have some foil and fiberglass insulation under the starter to protect it from the manifold)
Old Sep 25, 2005 | 11:15 PM
Eleanor Dreaming's Avatar
Fuel Cutoff switch is in case of impact the fuel is cutoff. Since the car has an electric fuel pump fuel would continue to be pumped unless the key were shut off. The reset is incae the switch is thrown is can be reset if there are no problem found in the car.
Old Sep 26, 2005 | 01:21 PM
DanteMO's Avatar
Thanx for the replies. I thought that's what it was but wasn't sure...
Does anyone know what that aluminum foil stuff is on the firewall under the master cylinder?
thanx
Old Sep 26, 2005 | 03:59 PM
Webba's Avatar
I am guessing but I would say the foil is a heat tape. In case lets say the master cylinder leaks out a little fluid and it drops on hmm the cruise control switch and wants to start a fire even when the vehicle isnt running. The tape might keep the heat and fluid out. Just a thought. perhaps they smartened up after all the recent fires.
Old Sep 26, 2005 | 04:39 PM
...'s Avatar
i'm guessing you have an auto.....if so its probally where the clutch unit would go through.
Old Sep 26, 2005 | 07:13 PM
DanteMO's Avatar
You da man...I do have an auto... You are probably right.
Old Sep 29, 2005 | 05:42 PM
mustangjack's Avatar
Unfortunately I found out how that works a couple of weeks ago in my 2002 Moutaineer. When I tried to move it after the girl ran the stop sign in front of me and I hit her. I coludn't get the car to start. I knew that I had seen something about it but I wasn't thinking clearly and couldn't remember what it was. It's a good thing, the tie rod was pretty bent and it wouldn't have gone straight anyway.
Old Oct 8, 2005 | 06:40 PM
Stangers's Avatar
If only they had those in the old Pinto's?
Old Oct 8, 2005 | 07:20 PM
htwag's Avatar
My old Pinto was a blast. Steering was unresponsive - move the wheel and about 15 seconds later, the nose would move.
Gill5oh
Oct 6, 2017 10:50 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
Sep 23, 2015 03:21 PM
bconboy
Sep 18, 2015 08:18 AM
bconboy
Sep 10, 2015 02:31 PM
