Silver Foil under master cylinder
All,
I was running some fog lights and have 2 questions:
I was under the drivers side dash and I saw a fuel reset button. What is it for? Googled it and found a bunch of hits on how to replace it, but doesn't say what it does? Is this a fuel cutoff switch in case the car flips and that button resets the switch?
and what is that silver foil panel right next to the master cylinder. Under the dash it's got a foam cutout?
Thanx in advance..
Thanx in advance..
Fuel Cutoff switch is in case of impact the fuel is cutoff. Since the car has an electric fuel pump fuel would continue to be pumped unless the key were shut off. The reset is incae the switch is thrown is can be reset if there are no problem found in the car.
I am guessing but I would say the foil is a heat tape. In case lets say the master cylinder leaks out a little fluid and it drops on hmm the cruise control switch and wants to start a fire even when the vehicle isnt running. The tape might keep the heat and fluid out. Just a thought. perhaps they smartened up after all the recent fires.
Originally posted by ...@September 26, 2005, 5:42 PM
i'm guessing you have an auto.....if so its probally where the clutch unit would go through.
You da man...I do have an auto... You are probably right.
If only they had those in the old Pinto's?
Sep 23, 2015 03:21 PM
