Seal exhaust leak!!!
Old May 21, 2011 | 11:35 PM
Victorfriessen's Avatar
Is there something magical that can be used to seal an exhaust leak?mines right between the headers and h-pipe,some silicon gasket ,any idea?
Old May 22, 2011 | 12:19 AM
Enfynet's Avatar
Is it at a clamp, or a hole in the pipe? If it's at a clamp, you can pick up some exhaust putty, if it's a hole in the pipe you might need to do a bit more...
Old May 22, 2011 | 06:45 AM
how are the 2 connected is it a band clamp there or is it a bolt together connection?
Old May 22, 2011 | 09:28 AM
Its a clamp,the thing is its not aligned properly and theres just not a way to bend them without a machine and i thought there could be something to use to seal it
Old May 22, 2011 | 09:32 AM
Heres some pics
Old May 22, 2011 | 04:15 PM
Enfynet's Avatar
Did you try loosening the other clamps to get them to flex into the right position? I had to do that when I installed my headers.
Old May 22, 2011 | 11:24 PM
Yea tried dat but no good results
Old May 23, 2011 | 12:28 AM
My old F150's manifold is slightly warped and blows out donut gaskets pretty regular. The only thing I've found that works longest is silicone for wood stoves. It lasts about a year. The high temp auto stuff only lasts about 3 or 4 months.
Old May 26, 2011 | 06:56 PM
if the pipe needs to be expanded a tad so the clamp will fit/seal better, you can get a free loaner pipe expander from autozone and do just that. I had to do that when I installed my xpipe.
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 24, 2015 08:15 PM
