sct tunner by evo performance for 06 gt
Old Sep 11, 2006 | 07:01 AM
saud alzaabi's Avatar
I own a 2005 5speed manual GT and it is purelly stock except that i just got me self a tunner with a custom 95 octane from fred @ evo performance.
i can feel a bit off power,but not the expected power,the rpm now can hit 6,500 and it easily chirps when shifting to 3rd,but i raced an automatic mustang which i really left him behind by 2 car lengths and i was still going slowly...,i raced a manual 350z and i ate him i get him easily,But i dont think thats the correct power i should have, well the reason is because in here we have the 95 octane and the 98 octane .. and i dont think its the same octane that other countries use,,, I MEAN USA off course.
so Im using our 98 octane for your 95 octane tune, and i can also see that my average miles per gallon is not what its used to be .. now my mustang is a gas hauler.. the 230 km from full tank got it to before the half by little but now its on the half... and what is worst is that the city mpg is not the way it used to be ... it drinks gas in the city more than the highway...
do u think i should reorder the tune ? and who has the best custom tune ? i know evo performance is great with tunes and is a specialist on auto tranny mustang tunes.. but who is the manual tranny custom tune specialist ?
im soon going to equip 4.10 gears and an aluminum drive shaft my mods are what i like to call stealth mods...
I want to have more power, safe power, something that cannot be seen normally, im thinking of u/d pullies with electric water pump and a better alternator ... which company or shop sells a better alternator ?
Old Sep 11, 2006 | 09:11 AM
34124231user's Avatar
We can get only 93 Octane here. I did not know that there was a 95 octane tune available anywhere. You use 98 Octane fuel? Holy crap! That's aviation fuel. The USA factory ford tune is for a poor grade, 87 octane fuel. When I installed my 93 Octane tune, my power went up, and my mileage went up, as well. I know that higher octane fuels burn faster and require ignition timing changes in order for the engine to function properly. I expect that the difference between a 93 octane tune and a 98 octane tune will not be all that much, in regards to power output, because gains will be limited by the factory piston compression ratio. Maybe somebody else can chime in here, as I am swimming a little out of my depth in regards to the relationship between octane and compression ratios.
With that kind of octane available to you, I think larger gains can be yours by going with higher compression pistons, in order to take advantage of the increased octane. Sometimes Octane alone will not increase performance significantly, even with a better tune. Good luck to you.
Old Sep 11, 2006 | 08:17 PM
65sohc's Avatar
So are you Saud, as in Saudi Arabia or where exactly are you? If all you have is a tune then you badly need a cold air intake. You won't be able to gain the full benefit of any other mod you do without a CAI as a foundation. As far as alternators are concerned, there is no need to replace the stock one. Slowing it down with UDP and then installing a higher capacity alternator, which eats up more power, defeats your purpose. I also don't think there is much point in going with both UDP and an electric waterpump. I personally would do the UDP since these slow down all the accessories, including the water pump. Granted I don't have either of these mods but most people report no problems with cooling, charging, or A/C with the UDP. Having said that, the temp got as high as 113 here in Fresno a few weeks ago and I was thankful for every BTU my A/C could produce.
Old Sep 12, 2006 | 05:39 AM
no my name is saud and saudi arabia is our neighbors i live in united arab emirates... some people know it as dubai ...
Old Sep 12, 2006 | 06:02 AM
ok so then how did fred give me a 95 octane tune if you guys dont have that octane.. was i cheated ? he is a nice guy and i dont think he does these stuff unless you guys have the 95 octane as a race gas...
here is a link of our fuel and stuff which i never understand .. thought some of you might http://www.adnoc-dist.co.ae/AdnocWeb...inProducts.asp
Old Sep 12, 2006 | 07:41 AM
kepfordj's Avatar
No, you weren't cheated. We have 100 octane race gas, and I run 105 octane E85 in my bike..I love the smell of that stuff in the morning.
trackpack13gt
Jul 25, 2017 05:29 PM
GeoWett
Sep 30, 2015 06:40 AM
oneeyedgiant
Sep 29, 2015 01:33 PM
Evil_Capri
Sep 25, 2015 12:56 PM
