Removing heat shield from K&N CAI...?
I think the heat shield might be the cause of some vibration/rattling. Are there any negative effects for removing it? I've heard that heat shields don't affect performance at all, but I don't want to remove it if the K&N was specifically designed for use with it and it won't work properly without it.
Thanks.
Thanks.
I removed it and it didn't fix the vibration. I had to say though, it looks much cleaner without the heat shield. I don't believe the heat shield does anything, so I think I'm going to leave it off.
Originally posted by adrenalin@October 11, 2005, 9:34 AM
some manufacturers don't use the heatshield such as MMR.
Lee from C&L pretty much said the same thing. Straight from the horses mouth, so to speak. He only included it, to make it appear to be a more complete kit.
If I'm not mistaken the very first ones he shipped did not have them. Same with the JLT, he added the shield later to satisfy the people who insisted on having one.
I can't see a significant amount of hot air affecting it when the car is in motion. Sitting still may be a different story, but in motion the hot air would be displaced anyway.
Keep running it without and judge for yourself if you can tell the difference or not.
