Removing heat shield from K&N CAI...?
Old Oct 9, 2005 | 03:38 PM
clockworks's Avatar
I think the heat shield might be the cause of some vibration/rattling. Are there any negative effects for removing it? I've heard that heat shields don't affect performance at all, but I don't want to remove it if the K&N was specifically designed for use with it and it won't work properly without it.
Thanks.
Old Oct 9, 2005 | 05:09 PM
ex-Galaxie500's Avatar
You'll be sucking in hot air from the engine compartment, which would defeat the purpose of having cold air intake
Probably not good for the engine to be breathing in hot air
Old Oct 9, 2005 | 05:59 PM
dustindu4's Avatar
9 is not my lucky number.
tighten it and find some way to dampen other vibrations
Old Oct 9, 2005 | 06:12 PM
clockworks's Avatar
I removed it and it didn't fix the vibration. I had to say though, it looks much cleaner without the heat shield. I don't believe the heat shield does anything, so I think I'm going to leave it off.
Old Oct 9, 2005 | 09:56 PM
94tbird's Avatar
the heat shield blocks hotter air form being sucked into the intake., datalog it with a tuner liek the Xcal2. It helps a WHOLE LOT more than u think
Old Oct 10, 2005 | 07:03 PM
Yes, it does do something, it does exactly what it sounds like it does... why do you think Ford has a box around the stock filter?
Old Oct 11, 2005 | 09:17 AM
clockworks's Avatar
Hmm, I guess I'll put it back on today.
Old Oct 11, 2005 | 09:31 AM
adrenalin's Avatar
some manufacturers don't use the heatshield such as MMR.
Old Oct 11, 2005 | 09:35 AM
clockworks's Avatar
Right, that's why I figured it was just for marketing purposes...but then a few people posted that it makes a very big difference.
Old Oct 11, 2005 | 10:32 AM
SixtySix's Avatar
Lee from C&L pretty much said the same thing. Straight from the horses mouth, so to speak. He only included it, to make it appear to be a more complete kit.
If I'm not mistaken the very first ones he shipped did not have them. Same with the JLT, he added the shield later to satisfy the people who insisted on having one.
I can't see a significant amount of hot air affecting it when the car is in motion. Sitting still may be a different story, but in motion the hot air would be displaced anyway.
Keep running it without and judge for yourself if you can tell the difference or not.
Old Oct 11, 2005 | 02:06 PM
clockworks's Avatar
Cool, Tony, that was the info I was looking for.
Road_Runner
Sep 2, 2024 04:46 PM
Mar 30, 2021 09:29 AM
