Pro 5.0 shifter install instructions
I purchased a pro shifter off a mustang forum and wanted to know where I can find a link for installing the pro shifter. I did find install instructions for a hurst shifter which I'm sure is the same concept but if I can find it for the pro would be great. Thanks for your help guys.
Originally Posted by dly
That link is for the SN95, not the S197. The Hurst instructions you saw should be basically identical, also go to mgwltd.com for videos on theirs. All the Mustang shifters are basically the same install method, maybe a bit different in adjustment and such.
Just FYI, I've installed the Pro 5.0 shifter in two S197s, my previous 2005 GT and my current 2008 SGT, and did not have to remove the driveshaft for either install. Its a little tight, but I had no problem doing this in my garage with a floor jack, stands and simple hand tools.
And thanks for all the info and the link.
Well I installed the shifter today and it's awesome. What I would like to do is change the handle and **** if that's possible, I like the way the hurst handle and **** looks and would like that look. What do you guys suggest? Thanks.
I have been running the Hurst handle/**** on my Pro 5.0 since installing the shifter and really like the set-up. Here's a place on Ebay with everything needed to install one including the chrome handle, **** and the boot grommet.
http://cgi.ebay.com/ebaymotors/Hurst...item53e6a96227
jim010
10/12/15 08:33 PM
Mr. Sparkle
8/21/15 10:10 AM
