Predator Trouble Codes....
Old Jun 10, 2005 | 10:20 AM
pumpkinfish's Avatar
Thumbs up
I just had my Bassani high flow cats and x-pipe installed. The guy who installed my x-pipe will also be inspecting it. He said in PA, there must be no codes when they plug in to the emissions computer. When I got home I was naturally curious if there were any error codes. So I checked it with my Predator and found these three codes:
P0325 Knock Sensor 1 Circuit Bank 1
P0330 Knock Sensor 2 Circuit Bank 2
P1000 OBD Systems Readiness Test Not Complete
So I cleared them out and drove the car around the block getting up to 65 mph on the main road. Came back checked codes again and what do you know? The same three are back. I don't need inspection yet, but how can I get these to stop showing up and should I be worried? Before the high flow cats and x-pipe, I was not getting error codes with every other mod listed below.
Here are all my mods on my auto tranny GT:
1. C&L Performance CAI with the C&L 93 octane tune altered to -5 global spark for 87 octane
2. Ford Racing Performance parts Hi-Flow shorty headers
3. Bassani X-Pipe high flow cats installed
4. Bassani Axle back
Old Jun 10, 2005 | 11:02 AM
porsche's Avatar
you said before the hiflow cats and x pipe it was fine!
sounds like the o2s are the problem .did you use the right o2 cable extenders?
Old Jun 10, 2005 | 11:08 AM
The ones I bought were for the 2004. I couldn't find any specifically labeled "2005". You might have found my problem as I thought the extenders should be the same. Am I wrong? If so who has the proper 2005 extenders?
Old Jun 10, 2005 | 11:14 AM
porsche's Avatar
bassani has them and should come with the auto kit!
Old Jun 10, 2005 | 02:59 PM
black gt 2005's Avatar
put the stock air box back on install the 91 octane or install the new c&l 91 octane tune . check for trouble codes .
Old Jun 11, 2005 | 07:58 AM
My biggest thing right now is will these trouble codes cause problems if I keep driving the car? I am getting the codes, but no SES light. I will try going back to the stock air box and stock tune as I understand no tune is required for the exhaust setup. I'll post my findings afterwards.
Old Jun 11, 2005 | 07:05 PM
As per your suggestion black gt 2005, I put the stock box back on. I also disconnected the battery for abot 1/2 hour and installed the origianl tune. I am still getting the errors on the Predator. I'll have to wait until I go through a tank of gas since I just filled up with 87, unless one of those octane booster products really work (I have always been skeptical of those products).
I have been reading about knock sensors and I'm wondering if the vibration from the Bassani exhaust may be setting them off?
Old Jun 12, 2005 | 05:08 PM
Jeffs05GT's Avatar
A knock sensor being triggered would generally indicate detonation would it not?
Old Jun 16, 2005 | 04:13 PM
pittperson's Avatar
I just put the C&L 93 octane tune on my car today and I could have sworn I heard some pinging (I could have been imagining things) so I checked for trouble codes with the Predator and found nothing. If there was indeed pinging/detonation the Predator would have picked it up correct?
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
mx5jhb
Sep 30, 2015 04:44 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
Airborne42
Sep 25, 2015 05:14 PM
akdoggie
05-09 Interior and Audio Mods
24
Sep 16, 2015 02:38 PM
