Panhard Rod
Old Apr 18, 2006 | 12:53 AM
GTracer's Avatar
My car was recently lowered and I have not gotten a new panhard rod yet. Is it really needed for a lowered car? And does it help handling at all?
Old Apr 18, 2006 | 04:24 AM
killo-11's Avatar
Helped mine.
Old Apr 18, 2006 | 06:19 AM
Dysan's Avatar
I think it depends on how much you lowered the car. I believe it's supposed to re-center the rear axle once the car is lowered 1.5 inches or more, but someone please correct me if I'm incorrect.
Old Apr 18, 2006 | 10:16 AM
rony1976's Avatar
you are correct, it will help you have the same distance between the tire and the wheelwell.
Old Apr 18, 2006 | 10:19 AM
Buck_Nekid's Avatar
An adjustable panhard will recenter the axle, yes.
However, the true benefit in the bar is how it holds the rear-end in place, stopping any side-to-side motion of the axle in the corners. The stock bar from the factory is good, but there is still (relatively) a lot of flex in it. This means that in heavy cornering, you can encounter lateral axle movement which destablizes the car.
So moving to a stiffer panhard, along with a stiffer brace will reduce flex and improve handling feel in the rear end.
09-gt/cs
Oct 15, 2015 10:03 AM
robjh22
Sep 8, 2015 12:31 PM
dohc97
Aug 3, 2015 06:26 AM
Jul 20, 2015 06:26 AM
