Panhard bar replacement question
Old Mar 23, 2025 | 02:00 PM
OneCoolGT's Avatar
I'm going to be replacing the panhard bar on my car and need to know if it can be done up on a lift or not? I currently have an adjustable Ford racing one in that's over 10 years old and the bushings are shot, I'm replacing it with a BMR adjustable one. Can the old one be taken off while it's up on a lift and the new one installed without an issue if it's set to the same length or does it need to be up on jack stands or ramps?
Thanks!
Old Mar 23, 2025 | 04:16 PM
05stangkc's Avatar
Here Are The Shop Manual PDF's & Updated & Complete Bolt & Flagnut Part Numbers as an FYI!
w711504-S-439
Replaces W704886
w710022s900 Flagnut
w710689s900 Flagnut
File Type: pdf
File Type: pdf
Old Mar 23, 2025 | 05:27 PM
m05fastbackGT's Avatar
Unless the rear suspension is supported by jack stands or ramps, the rear suspension won't be parallel with the panhard bar during the installation process...
Old Mar 24, 2025 | 06:06 AM
Bert's Avatar
If I remember correctly, I did mine with the car up on jack stands and without supporting the axle/wheels .... you may need to use a jack under the axle to get the holes lined up
the final adjustment will need to be done with the suspension compressed to ride height -- meaning the weight of the car on the tires. Also a good idea to do the final torque on the bolts with the car at ride height.
Old Mar 24, 2025 | 04:08 PM
Just an FYI: In order to get the holes lined up requires supporting the rear axle by placing either jack stands or a floor jack under the rear axle...
Old Mar 25, 2025 | 07:27 PM
OneCoolGT's Avatar
Thanks, the dealer put it on when I got it years ago but not sure how they did it. Wheels are lined up properly and the car is lowered by and inch and a half in the rear.
Jazzman442
75
Mar 28, 2017 03:27 PM
dohc97
Aug 3, 2015 06:26 AM
mdazi
May 23, 2013 09:05 AM
azoufan
Apr 28, 2007 12:14 PM
