Normally Aspirated Performance
Old Jul 25, 2010 | 10:07 AM
RGNUSMC's Avatar
What are the best mod combinations to boost power without a supercharger?
Old Jul 25, 2010 | 10:30 AM
2010MustangGT's Avatar
I'm looking into this myself...
Cams and Long tubes will net the most.
Along with a CAI, Throttle Body, U/D pulleys, Tune of course..., exhaust.
Other things are like Charge motion delete plates, Manifold, and electrical water pump. All net some HP.
Old Jul 25, 2010 | 10:50 AM
70MACH1OWNER's Avatar
I am a good one to answer this since I believe I have done everything possible to my car and stayed N/A. But while I am very happy with the performance of my car it still isn't a cheap adventure. Here is a list of my mods in the order I would do them if I could do it all over. My list is by what I feel is the best seat of the pants gains. Not horsepower on a dyno. Some will disagree. For the record I have a 05 Convertible GT with an auto transmission. So if your a manual your order will be different.
C&L intake with Brenspeed 93 octane tune
NSR Comp Cams
4:10 rear gear
3000 rpm stall torque converter
Longtube headers without cats
1 piece aluminum driveshaft
Delete plates
Meziere electric waterpump/Steeda Underdrive pullies
These are the biggest item that will give you the biggest boost. It has been over 2 1/2 years since I have been on a dyno. Before the gears, torque converter my auto trans car put down 315/311 on Brenspeeds dyno. If you have a manual trans your numbers would be about 20/20 higher than mine. Hope this helps.
Scott
Old Jul 25, 2010 | 02:28 PM
obofglob's Avatar
Gained approx. 20-25 H.P. with Steeda UDP's, C&L CAI and a dyno tune.
An additional 50 R.W.H.P. with FRPP Hot Rod cams, FRPP Throttle body, new FRPP 3V intake and Kooks LT's with a catted H Pipe.
I don't think it's easy or inexpensive to make NA power but I am very pleased with the results.
Also went from 3.73's to 4.10's probably the best mod, especially with the cams and intake.
Old Jul 25, 2010 | 02:46 PM
harristotle's Avatar
Do any of any of you with the higher HP N/A setups have videos of your cars running? I would love to hear what some of these sound like.
Old Jul 26, 2010 | 11:16 AM
Mustang05's Avatar
*Naturally
Old Jul 29, 2010 | 05:59 PM
PIKE2244's Avatar
I have Cams, Heads, LT's, Catted H, Intake, Custom Tune and a few minor things and I am putting down about 370rwhp... Just ordered FRPP Manifold and Throttle body so lets see what the numbers are in a few weeks...
Old Jul 29, 2010 | 06:52 PM
Casey4s's Avatar
NSR Comp Cams
4:10 rear gear
Delete plates
Scott
You and I are pretty much the same except I have a JLT intake, and Hot Rod cams, with a 60 mm TB. I will be getting a new dyno tune soon so I will see wht the HP is then. The only other items I'd like to have is the new FRPP manifold, and FRPP ported heads.
Old Jul 29, 2010 | 09:19 PM
PIKE2244's Avatar
I guess I need some 4:10's in the near futures as well!!!!
May 3, 2026 05:42 AM
oneeyedgiant
Nov 16, 2015 12:23 PM
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
Evil_Capri
Sep 25, 2015 12:56 PM
