newbie to nitrous. HELP
Old Feb 24, 2011 | 07:44 PM
Mikes_BLK_GT's Avatar
got a quote today for $5 per lb. no labor, I might have to look further into this option since I may never have the kind of cash for an SC or turbo
Old Feb 25, 2011 | 07:39 AM
lightningfan's Avatar
I pay 4.25/lb, a blow down tube is there to release pressure not prevent burst in an accident. If you crack the bottle a blow down tube will do nothing. If you live in a cold climate be careful with a bottle warmer as it has been known to crack bottles when trying to heat up from too cold of a temperature. If you need it warm in freezing weather submerge it in water instead. Anything can happen in the event of an accident, if it was my child the bottle would be removed when they are in the car just in case I was rear ended.
Old Feb 25, 2011 | 07:40 AM
FYI
Make sure they freeze the bottle prior to fill up.
Old Feb 25, 2011 | 02:47 PM
Can I run Hot Rod or Detroit Rocker cams with this setup or would I need to upgrade the fuel system?
Old Feb 25, 2011 | 04:39 PM
Bullitt995's Avatar
Spend the money on your fuel system. It's never money wasted, it's difficult to make a fuel system too powerful.
Old Feb 26, 2011 | 04:22 AM
So I'm thinking about this setup:
Zex kit(start out at 75 but will want to try 100 and 125 as well)
TPS switch
window switch
purge kit
pressure gauge
bottle heater
39lb injectors
Kenne Bell BAP(The GT500 pumps are too expensive for me)
HT0 spark plugs
FRPP Hot Rod or Brenspeed Detroit Rocker Cams(haven't decided)
LT's eventually
Old Feb 26, 2011 | 05:07 AM
There are a couple different Zex setups for our cars. If you go with the typical 82034 kit then you don't need the TPS switch, it's within the NMU. I would invest in fuel and nitrous pressure gauges. Electrical if your budget allows.
Old Feb 26, 2011 | 05:30 AM
Katfish's Avatar
I live in sunny Florida where the temps never get below 50. At what temps do you need the bottle warmer, or is it just a performance improver?
Old Feb 26, 2011 | 10:26 AM
Bullitt995's Avatar
TPS switch
window switch
purge kit
pressure gauge
bottle heater
39lb injectors
HT0 spark plugs
LT's eventually
I would buy the fuel pumps and skip the cams but that's just me.
Yes you should always have a bottle warmer so you can achieve the proper bottle pressure.
Old Feb 26, 2011 | 02:07 PM
Cams have been planned for awhile now and would go in despite any power adder plans.
Revised List:
Blow Down kit
window switch
purge kit
Bottle pressure gauge
Fuel Pressure gauge
Nitrous Pressure gauge
bottle heater
39lb injectors
HT0 spark plugs
LT's eventually
Old Aug 26, 2014 | 07:30 AM
nitrous3valve's Avatar
help with tune
Chris rose, I have a bama tune. My car has a bbk 62mm twin TB, spectre 100mm maf housing I believe, long tube headers 2.5" collector's 1.750" primarys, ford racing hot rod cams, Bama 93 tunes, charge motion plate delete, off road Hpipe. I have a cheap dynotune nitrous kit I got from ebay. From my last fox body I had two nx super shot solonoids good till 400hp shot. I ended up using the dynotune solenoid for my purge and it works good enough to bleed the lines. Anyways my kit bases their jet sizes off the flywheel and comes with 75-150 shot. It works great with the nx solonoids hits hard as ever with the "150" shot in. According to nitrous express jet chart my "150" shot is actually a 125rwhp. So I bought .067 nitrous and .038 fuel. That is 175rwhp and 200bhp. If I go into my tuner can I pull timing from my global timing? And do u recommend I add fuel at WOT. If so how much. If it blows it blows this winter I was going to find a old 5.4 3v and forge the lower and bolt up all my stuff to it. I am running autolite ht0 plugs stock gap. Stock fuel system. What should I do about the timing and wot fuel? I know bama won't tune over a 100 shot. Also say if I wanted to just keep the 125 in could I data log my car and send YOU the file so I could have u tune it. I am looking for as much as u can give me. Safety is not really to much of a concern at this point because I am losing that motor this winter. So I wanna finish the end of the season at least breaking into the 11s just once before the build. Please get back with me I would love to have u take a look at my tune and make some changes. My tune seems very conservative, I feel like the car should have more in it when I run the motor tune. It's seem like it was faster with the stock cams.
Old Aug 26, 2014 | 07:33 AM
help with tune
Old Dec 16, 2022 | 12:53 PM
Caleb23's Avatar
Originally Posted by AMChrisRose
I've got customers about to hit 75,000 miles with heavy nitrous usage from atleast 20,000 miles and on. 125 shot. As long as it's tuned right (call me! LOL) and you have the right stuff, you'll never have an issue. The setup I sent you with stock plugs and 75 shot is MORE than safe. The setup I sent you with one step colder Autolite HT0 plugs and 100-125 shot is decently safe. 150 shot is getting out of the zone of "safe" and becoming dangerous... plus you're on the verge of maxing out your fuel pump. 175 shot is where you are in the danger zone, and you've already maxed out the stock fuel pump. So basically, 125 shot and down (preferably 75-100 shot) and you'll be just fine! I'd still get the HT0 plugs (stock gap out of the box).
Do you still tune for 3vs ? I need a tune. Lol if so how can I contact you
Thomas S
16
Mar 2, 2006 01:48 PM
StangFreak
May 16, 2005 08:51 PM
N.Tufnel
May 13, 2005 04:45 PM
1 COBRA
Feb 13, 2005 02:04 PM
Clutch
1994-2004 V-8
18
Jan 12, 2005 09:02 AM
