NEW! 2005-2009 Mustang Edelbrock E-Force Supercharger System!
Old 12/19/08, 03:25 PM
  #121
RedDragon777's Avatar
ok now someone has to sell me on this kit ALL OVER again cause after i saw the Kenne Bell "Mammoth" kit for our cars i am wondering if i should go with that or this kit.
Old 12/19/08, 05:43 PM
  #122
AFChief's Avatar
If I planned on strengthening the lower end, KB would be my choice. The Mammoth would be overkill if you want to keep stock internals.
Of course, I'm not an expert and didn't even stay at Holiday Inn Express last night!
Old 12/20/08, 12:32 PM
  #123
WayneA's Avatar
Nice SC, even with the cheese valve cover covers, any more info on the “available” 36 month/36K mile warranty? What do they mean by “available”? I assume it’s not included. Does it have to be installed by a “certified” shop, or just an added expense?
Old 12/20/08, 01:35 PM
  #124
i bet it has to be installed at one of their certified dealers just like FRPP and Roush parts only get the warrenty if they are installed at a qualified Ford dealership
Old 12/23/08, 11:05 AM
  #125
Former Vendor
TillmanSpeed's Avatar
NEW INFORMATION ON THE EDELBROCK E-FORCE SUPERCHARGER KITS:
http://www.tillmanspeed.com/Edelbrock_EForce.pdf
EDELBROCK WILL BE OFFERING THE FOLLOWING ADDITIONAL REPLACEMENT PARTS AND UPGRADE KITS TO THE SUPERCHARGER, AS WELL AS A TUNER SUPERCHARGER KIT (COMPETITION KIT) THAT WILL ALLOW YOU TO PICK DIFFERENT COMPONENTS!
COOLING SYSTEM UPGRADE KIT
FOR 2005-06 FORD MUSTANGS
Our Cooling System Upgrade Kit is necessary when installing the new Edelbrock E-Force Supercharger Kits #1580 and #1585 in a 2005-06 Mustang GT. This kit relocates the thermostat from the cold side of the radiator to the hot side for improved cooling. Kit contains all necessary hoses, clamps and hardware.
(for 2005-06 Ford Mustang GT).................................................. ..#15804
HARDWARE KIT
FOR 2009 FORD MUSTANG
This kit is required when installing the new Edelbrock E-Force Supercharger Kits #1580 and #1585 in a 2009 Ford Mustang GT. Includes new intake gaskets and all the necessary hardware for 2009 specific installation.
Hardware Kit for 2009 Ford Mustang GT .................................................. ............#15805
BELT TENSIONER BRACE
This new belt tensioner brace is intended for use on 2005-09 Mustangs and F-150 trucks with an
aftermarket supercharger installed. The stock belt tensioner is cast aluminum and has been known to bend and even break under extreme driving. The Edelbrock Steel Belt Tensioner Brace is an inexpensive solution to this common problem. It simply bolts on to your stock tensioner and prevents any deflection of the cast arm. Already included with E-Force supercharger kit #1580 (street) and #1585 (competition).
Steel Belt Tensioner Brace .................................................. ...............................#15806
FUEL INJECTORS
Fuel Injectors
(41 lb/hr, EV14, USCAR, 60mm Body, Set of 8).................................................. ....#15807
COMPETITION COMPONENTS
E-FORCE COMPETITION SUPERCHARGER KIT
The Edelbrock E-Force competition supercharger is based off of our street supercharger kit #1580, but is paired down to the essential components that a racer needs, without the extras that experienced racers prefer to customize for their own competitive advantage. This kit contains: supercharger manifold assembly featuring, 85mm electronic throttle body, cast aluminum alternator/idler bracket, steel belt tensioner brace, cast aluminum water crossover, dual core low temperature heat exchanger for intercooler system, electric intercooler water pump, intercooler recovery tank, -12 AN intercooler fittings, steel idler pulleys with heavy duty high speed bearings and all the necessary mounting hardware, wiring and plumbing. For competition racing use only.
E-Force Competition Supercharger Kit
(for 2005-09 Ford Mustang 4.6L 3V) ............................#1585*
E-FORCE COMPETITION AIR INTAKE SYSTEM
The E-Force Competition Air Intake System includes a high flow, 95mm, Mass Airflow Sensor (MAFS) capable of supporting up to 90 lbs/min of air flow. It includes an 8" long, reusable, open element filter with plastic shroud. This system is for use with Competition sSpercharger kit #1585.
E-Force Competition Air Intake System .................................................. ..............................#15808
PULLEYS FOR E-FORCE
COMPETITION SUPERCHARGER KITS
E-Force Competition Supercharger Pulleys are required for installation of E-Force Supercharger kit #1585. Available in four different sizes for fine tuning air flow needs for your specific racing needs.
3.50" Pulley............................................ .................................................. .......#15820
3.25" Pulley............................................ .................................................. .......#15821
3.00" Pulley............................................ .................................................. .......#15822
2.75" Pulley............................................ .................................................. .......#15823
WE ARE OFFERING STAGED E-FORCE PACKAGES AS OF NOW, DETAILS COMING IN OUR NEXT POST BELOW!!!!!
Old 12/23/08, 01:29 PM
  #126
Black GT500's Avatar
I really like that intake and intercooler design!
Any absolute word yet on whether it fits under the factory Bullitt Strut Tower Brace?
Gotta be able to keep the Bullitt factory "serialized" strut tower brace.
Attached Thumbnails NEW! 2005-2009 Mustang Edelbrock E-Force Supercharger System!-img_6991c.jpg
Old 12/23/08, 03:03 PM
  #127
Doogie's Avatar
Chris, does this mean we are getting closer to these shipping??? I am getting anxious and can't wait to see that part in my garage... and then ultimately on my car!
Old 12/23/08, 10:30 PM
  #128
CO_VaporGT_09's Avatar
Originally Posted by TillmanSpeed
Hey Chris
TMS says you've exceeded your PM quota, hope you'll see this here:
Got the code: FBNF1G3.
I assume you email the new files?
I can't get the SCT software to install on Windows Vista, is that a known problem?
Thanks Chris.
Josh
Old 12/24/08, 10:13 AM
  #129
Former Vendor
PM box is open. Will knock it out for you Friday! THANKS!
Old 12/26/08, 03:05 PM
  #130
travelers's Avatar
Originally Posted by CO_VaporGT_09
So, anybody know which one "lysholm" applies to? ( I think it's twin screw).
They make the Whipple and Kenny Bell twin screws
Old 12/29/08, 03:41 PM
  #131
Former Vendor
Lysholm (Swedish) makes twin screw blowers. They also manufacture the new Vortech twin screw as well. This Eaton TVS four lobe roots style blower is made in America.
Chris Rose
Tillman Speed Inc.
www.TillmanSpeed.com
610-497-5776
Old 12/29/08, 10:28 PM
  #132
S197GodOfPain's Avatar
I have not herd a max psi, and i mean at a constant level, not on a dyno for 2 seconds. KB is 25 psi what is this one.
Old 1/4/09, 06:07 AM
  #133
Hatchman's Avatar
Who is getting the first one and when is it getting installed?
Old 1/4/09, 07:48 AM
  #134
Doogie's Avatar
I've got one coming and will be installing myself, just patiently awaiting a delivery date from Tillman. As of last week, CR was speculating they may start shipping this week as Edelbrock was shut down over the holidays.
Chris, any update??
Old 1/4/09, 09:12 AM
  #135
mustangbaxter's Avatar
I ordered mine from a Edelbrock ' National Sales Manager '. He told me today that there still targeting a FEB 1 date.
Thats all I know for now. I do know that I have to remove my Saleen UDP's. Any one want a killer deal on a set of less than one year old saleen UDP's?
Tim
Old 1/5/09, 03:45 PM
  #136
Former Vendor
Just to let everyone know, this kit WILL fit underneath the factory Bullitt strut tower brace!
Chris Rose
Tillman Speed Inc.
Old 1/5/09, 03:52 PM
  #137
Thumbs up
Chris,
That is outstanding, thanks for the confirmation!
Chris Rose
Tillman Speed Inc.
Old 1/5/09, 04:36 PM
  #138
Doogie's Avatar
That's great news Chris as I was holding off getting one until after the install... now I can be on the look out for a good deal on one!
Old 1/5/09, 07:16 PM
  #139
Former Vendor
Thank Rob Simons, mastermind over at Edelbrock for that one! That guy is an engineering madman!
Chris
Old 1/5/09, 07:30 PM
  #140
Doogie's Avatar
But now you just need to get me that SC shipped! Did you find out anymore details today??
Quick Reply: NEW! 2005-2009 Mustang Edelbrock E-Force Supercharger System!
