NEW! 2005-2009 Mustang Edelbrock E-Force Supercharger System!
Old Oct 29, 2008 | 12:18 PM
TillmanSpeed's Avatar
Former Vendor
Coming soon from Tillman Speed Inc.! Custom Tuning, Pricing, and Dyno Results Available Soon! System is due to be released shortly after SEMA (Next Week)!
Edelbrock E-Force Supercharger System for 2005-09 Ford Mustang 4.6L
TORRANCE, CA - Edelbrock is excited to announce the release of their E-Force Supercharger system for 2005-09 Ford Mustangs equipped with a 4.6L 3V. This all-new design is engineered and manufactured by Edelbrock and features an Eaton® Twin Vortices Series (TVS®) GEN VI rotor assembly - the same internals used on the new Corvette ZR-1. This combination improves 2005-2009 4.6L 3-valve Mustangs to an impressive 466 horsepower and 439 ft./lbs. of torque on only five (5) pounds of boost; this is more power per psi than any Mustang supercharger system on the market today.
The supercharger assembly is integrated into Edelbrock's unique intake manifold for a truly seamless design with minimal components. The intake features 15" long runners for maximum low-end torque and an integrated bypass valve that helps reduce parasitic loss under light throttle, which improves mileage potential. Keeping the air cool is a 110 square inch high capacity air to water intercooler - the largest of its kind available on the market today - and dual core low temp heat exchange. This Edelbrock E-Force supercharger assembly includes a matching set of coil covers uniquely styled to give your engine compartment a custom look.
This complete Edelbrock E-Force supercharger kit includes everything you need to bolt it on under the hood of a 2005-2009 Mustang 4.6L 3V, including supercharger/manifold assembly, air inlet with 85mm throttle body, fuel injectors, air-to-water intercooler, spark plugs, coil covers and handheld flash programmer to properly tune the factory ECU for the added power. Edelbrock offers an available 3-Year/36,000 mile warranty and 50-State emissions legal EO is pending.
  • Features Include:
  • More horsepower per psi than any other Mustang system on the market
  • 2300cc (140 cubic inch) Eaton® TVS® GEN VI rotor assembly
  • Unique intake manifold design with 15" long runners for increased low-end torque
  • 100,000 mile self-contained oiling system
  • Installs under the stock hood while maintaining factory accessories
  • Complete package includes supercharger/intake assembly, air inlet with 85mm throttle body, fuel injectors, air-to-water intercooler, spark plugs, coil-covers and flash tuner with proper calibration
  • Available 3 Year/36,000 mile warranty
  • The most efficient system available - 466 HP and 439 ft./lbs of Torque on only 5 lbs. of boost!
  • Made in USA for absolute quality and performance
AVAILABLE AT TILLMAN SPEED INC! CUSTOM DYNO TUNING IN-HOUSE ON OUR DYNOJET 224XLC USING SCT FLASH ADVANTAGE III CUSTOM TUNING SOFTWARE!
Chris Rose
Tillman Speed Inc.
www.TillmanSpeed.com
In-House Dynojet 224xLC
610-497-5776 or 3736
Old Oct 29, 2008 | 12:36 PM
05fordgt's Avatar
Thats pretty dang impressive numbers CR. The icing on the cake, would be if the coil covers could be custom painted/powdercoated to give it a stand out look! I'm eager to see dyno numbers on this system.
Old Oct 29, 2008 | 01:07 PM
officespace56's Avatar
Is the PSI able to be pumped up for more power?
Old Oct 29, 2008 | 01:14 PM
Former Vendor
That would be sweet!!!
Old Oct 29, 2008 | 01:36 PM
LEO_06GT's Avatar
Are those two big black things that say "supercharged by edelbrock" a functional part of the supercharger or just some fugly plastic to cover up the engine bay?
Old Oct 29, 2008 | 01:59 PM
Former Vendor
The latter of the two.
Side note: Tokico finally got ahold of me. Give me a shout, or I can PM you.
Old Oct 29, 2008 | 02:09 PM
LEO_06GT's Avatar
A good. I'm sure most people will be tossing those two pieces. The rest of the setup looks killer though. The tech specs aren't bad either.
I'll give you a ring shortly.
Old Oct 29, 2008 | 04:27 PM
Former Vendor
I'm talking with Edelbrock right now about PSI levels. I imagine you'd only have to run 7PSI to get 480+RWHP on this setup. I love the throttle body setup, needs an aftermarket box though.
Chris Rose
Tillman Speed Inc.
610-497-5776
Old Oct 30, 2008 | 07:52 AM
travelers's Avatar
Chris Rose
Tillman Speed Inc.
610-497-5776
Whats there take on the fuel system up grade and MAF? 85mm sounds a little small. I would also like to see a dyno sheet on this setup on a total stock motor.
As for looks it does look good except the corvette style covers. we don't need no stinking covers......
Old Oct 30, 2008 | 08:54 AM
Former Vendor
I think we're going to end up swapping out for a 90mm Steeda HF elbow and intake and 7PSI on our upgrade kits.
I am getting tech info on the fuel system as soon as my rep from Edelbrock is back in today!
Chris Rose
Tillman Speed Inc.
610-497-5776
Old Oct 30, 2008 | 09:45 AM
travelers's Avatar
Chris Rose
Tillman Speed Inc.
610-497-5776
You want to test it out on my car????????????????????????????????????????/
Old Oct 30, 2008 | 09:57 AM
WaltM's Avatar
Interesting.... Do you have a MSRP?
Old Oct 30, 2008 | 09:59 AM
SuperSugeKnight's Avatar
Reminds me of the old Allen Supercharger systems.
touring's Avatar
Man you guys are crazy, just when i was finally set on the KB S/C you guys come out with this......
Old Oct 30, 2008 | 10:00 AM
touring's Avatar
+1
Old Oct 30, 2008 | 10:13 AM
Former Vendor
MSRP was just announced at around $6000 via Smitty Smith, Technical Sales Coordinator @ Edelbrock!!!!
We will have as much technical info and pictures as possible starting Tuesday at the SEMA show! The coil covers are removable!!!
We will be offering an option for 7-9PSI and a high flow intake which should push this kit up to over 480-520RWHP SAE corrected!
Old Oct 30, 2008 | 10:40 AM
soitsav6's Avatar
any idea about C.A.R.B. certification on that puppy? for us CA folks?
Old Oct 30, 2008 | 11:11 AM
Former Vendor
Carb Pending.... I don't know about CALI yet, but being that Edelbrock is right in Cali, I'm sure you'll be covered!
Chris Rose
Tillman Speed Inc.
610-497-5776
Old Oct 30, 2008 | 11:13 AM
69Mach1-409's Avatar
...I want one!
Former Vendor
Me too... now I gotta buy a **** S197!
