Need and Adj PHB - Sugestions?
Old Jun 25, 2011 | 10:52 PM
Fords4Ever's Avatar
After the Steeda Sports install the rear end is shifted a ways to the passenger side. I read somoene here say that it should shift to the driver's side if at all.
Does that mean something is wrong because it shifted the other way?
Also what PHB recomendations do you guys have? I'm thinking poly ends, nothing exotic, just need to get her centered. She's pulling to the right pretty bad at this point.
Any PHBs to stay away from?
BTW it dropped about 1.25" in the rear and right at 1" in front.
Old Jun 26, 2011 | 03:05 PM
Cavero's Avatar
That's interesting that it would shift to the passenger side, the attachment point for the panhard rod to the chassis on the passenger side so as the arm swings, you would expect it to pivot around that point and go more to the driver's side. I don't necessarily know if anything is wrong with your car though, factory tolerances aren't all that great. Some people have noticed that their rear ends were off after getting wider rims, and their cars were never lowered.
I have the Steeda adjustable PHB. I like it just fine, it's been very solid for the last 4 years. The only thing I don't like about it is the locknuts are at the ends of the bar. On the driver's side, that's fine. On the passenger side, it gets to be a bit of a PITA because the chassis mount kind of gets in the way. I ended up grinding down one side of an open ended wrench to make it fit better, so I could tighten it down properly. I also had to use locktite because I guess I couldn't torque it enough to keep it from loosening up after a couple days of driving. After I did the Locktite, it hasn't given me any trouble whatsoever.
The only competitor I know anything about is BMR. Their adjustable PHB has the adjustment mechanism in the center of the bar, so you don't have to worry about getting a wrench to fit with the clearance at the chassis mount. For some reason, it doesn't seem to me like it would be as strong, but you'd have to talk to someone that actually has that bar.
Old Jun 26, 2011 | 03:57 PM
SoFlaBoss's Avatar
I recently got a J&M Adjustable Panhard Rod for my 2008 Shelby GT from American Muscle (AM) for $96.81 shipped. This was while it was on sale through 5/31 for $102.99, less another 6% using an AM Coupon Code that you can request from AM as a member of TMS. The bar (link below) is now selling for $114.95, but it still a great value. It also has the adjustment on the ends, but is made from billet aluminum, so it will never rust.
http://www.americanmuscle.com/jm-pan...0%5E1%5E102.99
Old Jun 28, 2011 | 10:03 PM
ETNOATS's Avatar
I got the BMR one five years ago and havent had one issue. Little pricier than some but worth it in the long run.
Old Jul 1, 2011 | 07:51 PM
randy_tho's Avatar
I also have the Steeda and a brace to go with it. It is kind of a pain on the passenger side but seems to do what it needs to well. It is chromoly and seems sturdy.
Btw, After your front alignment where did your Steeda mounts end up with the adjustment indicator?
TacoBill
19
Nov 16, 2013 10:35 AM
EastCoast07GtCs
14
Jun 9, 2008 06:19 PM
EastCoast07GtCs
Jun 3, 2008 08:00 PM
johnnyluvchx
05-09 Interior and Audio Mods
Feb 5, 2008 03:52 AM
Shibbiestang
Sep 18, 2004 11:34 AM
