msd window switch w/ zex system
how do i wire in a msd window switch to a zex system, they way i hooked it up didn't work. i just need to know where and how to wire in the normally open wire off the window switch. i have power ground and rpm hooked up right.
Christ I forgot where the relay goes. The basic idea is to have the zex box completly turned off while out of the rpm range then when you enter the set rpm range, it turns on. It's hard because you can't get to the WOT or solenoids. It can be done though.
9/24/15 08:15 PM
9/10/15 12:44 PM
