msd window switch w/ zex system
Old Mar 20, 2007 | 04:57 PM
onebadgsx's Avatar
how do i wire in a msd window switch to a zex system, they way i hooked it up didn't work. i just need to know where and how to wire in the normally open wire off the window switch. i have power ground and rpm hooked up right.
Old Mar 20, 2007 | 05:43 PM
Bullitt995's Avatar
I've done it before. It's not pretty but it works. I'll post a simple picture from paint in a little bit.
Old Mar 21, 2007 | 12:30 PM
onebadgsx's Avatar
bullitt you worked up that pic yet?
Old Mar 21, 2007 | 09:16 PM
Bullitt995's Avatar
Old Mar 22, 2007 | 06:07 AM
onebadgsx's Avatar
the yellow wire is normally open and will add a ground once the rpm is reached. are you sure about that wiring? i dont need a relay?
Old Mar 22, 2007 | 08:23 AM
Bullitt995's Avatar
Christ I forgot where the relay goes. The basic idea is to have the zex box completly turned off while out of the rpm range then when you enter the set rpm range, it turns on. It's hard because you can't get to the WOT or solenoids. It can be done though.
Old Nov 6, 2008 | 03:09 PM
jamesdem1123's Avatar
with the msd, which wire did you use to connect to the tach signal, did you use a coil wire? if so which one closest to the battery? thanks
Old Nov 6, 2008 | 06:07 PM
Bullitt995's Avatar
Did it on one of the coil wires on the #1 cylinder. The first one on the left when you're looking at the car from the front.
kponypower
Jun 17, 2020 07:17 AM
Sep 24, 2015 08:15 PM
Sep 10, 2015 12:44 PM
