Meziere install and the relay ignition-on sense wire
#84
well i pretty much forgot to take any pics haha. got too involved and forgot to stop for pics. jsut how important is that bottom bolt haha? i cant seem to get it in at all. i taped the bolt to the allen wrench im using but even so still cant get it in. the top 3 were easy once i removed the alternator
#85
ok its in. the bottom bolt still hasnt seated correctly. there is a gap between the bolt and the pump/block i am going to use a lock washer on it and be done with it. it will take up the gap and keep even tension all around. the top 3 bolts were easy as hell after i removed the alternator and my idler pully bracket(I have a KB supercharger). the wiring was extremely easy
Blue wires get crimped/soldered/heatshrinked together. black wires get grounded, orange wire went to the fuse box power wire, and the green went into an add-a-circut into fuse slot 40. all wires hidden and in wire loom. looks like a factory job. i got the coolant from 192 degrees F to 138 Degrees F in jsut over 500 seconds running the pump and my fan. not a bad deal. i jsut hope nothing leaks.
i did not drain the coolant, jsut pulled the old out and slapped in the new.
i also noticed that when driving the car, the idiot temp gauge is in the same spot as normal, but when you come to a red light, it drops all the way down to a quarter. not too shabby!!!
#87
#88
#89
![](http://i20.photobucket.com/albums/b238/94tbird/ElectricFanSwitch1.jpg)
my relay is here. my fuse box and computer are relocated due to the kenne bell blower so i used the old mounting holes for the fuse box to mount the 2 relays, 1 for the intercooler pump and one for the electric h20 pump. so unless you have the kb blower, this wont work for you
![](http://i20.photobucket.com/albums/b238/94tbird/IMAGE_00183.jpg)
Mr. Sparkle
9/11/15 02:57 PM
robjh22
9/8/15 12:31 PM
