Meziere install and the relay ignition-on sense wire
Old Sep 10, 2006 | 07:31 PM
Redfire 05Gt's Avatar
Where in the fuse box wiring did everyone tap into for the "relay ignition-on sense" wire?
Step 9 in the instructions says to "Disconnect the factory wiring harness (located on the passenger side firewall) and locate pin number 9 on the plug, indicated on the outside of the plug." but I'm sure they're referring to pre-05.
I read thread in this thread http://forums.bradbarnett.net/showth...eziere+install where it's mentioned to use one of the 2 red wires that enters the fuse box. I dug inside the three wire bundles that enters the right side of the fuse box and found one red wire in the larger, middle bundle. Just thought I'd post here before I go ahead and tap into it...
Thanks!
Old Sep 11, 2006 | 06:00 AM
dustindu4's Avatar
9 is not my lucky number.
I'm told it's in the middle bundle as well
Old Sep 11, 2006 | 06:34 AM
FireFighterHill's Avatar
Use a add a fuse its SO much easier
Old Sep 11, 2006 | 09:48 AM
Thanks!
Add-a-fuse?
Old Sep 11, 2006 | 10:45 AM
LordBritish's Avatar
Is the water pump dificult to install??
To give you an idea of how competent I am, it took me 3 hours to install axle-backs - hahaaha.
If this is much more complicated than axle-backs then I probably wont be able to install the pump and will have to pay somebody.
Sounds like it can be tricky.
I just love how some people assume that you have access to a lift and tons of power tools and can rebuild a tranny - haha..
Old Sep 11, 2006 | 11:24 AM
Well basic knowledge of wiring is required. Get the wiring kit. The HARDEST part is getting the **** bolts in, the bottom one in particular.
Old Sep 11, 2006 | 12:31 PM
mrkabc's Avatar
Sounds like my 1980's era Chilton manual for my Fox Stang:
FIX YOUR PROBLEM IN FOUR E-Z STEPS!
STEP ONE: Remove engine.
STEP TWO: Fix problem.
STEP THREE: Replace engine.
STEP FOUR: Wash hands.
Old Sep 11, 2006 | 12:44 PM
Can somebody post detailed instructions on how to install this H2O pump.
I already have Steeda UDP installed so I need a shorter belt - that much I do know.
I'm thinking of doing this but my confidence level in my mechanical/electrical abilities is not high. It's also my only car and daily driver so it has to work !!
Old Sep 11, 2006 | 02:55 PM
Is that how you did yours, with an add-a-fuse?
Old Sep 11, 2006 | 02:56 PM
There's some info here: http://www.modularfords.com/forums/2...ead-33474.html
Old Sep 11, 2006 | 05:34 PM
94tbird's Avatar
i tried and failed the first attempt. could not get the F***in bolts to go in at all. put the stocker back. it is **** near impossible and not as easy as the link made it seem and thats coming from someone who has installed 2 superchargers on our engines to date.
Old Sep 11, 2006 | 08:41 PM
Yeah I used a add a fuse. I dont wanna splice into the factory harness.
Old Sep 11, 2006 | 09:17 PM
don_w's Avatar
It took me about 5 minutes to get the bottom bolt in. hawgman told me the trick. Use a small piece of double-stick tape on the end of the ball-end allen wrench. The first time I tried it, the bolt fell off. Then I cleaned the wrench and the bolt head with some iso-alcohol, and it stuck nicely. Then it went right in on the first try.
BTW, I didn't even drain the coolant from the car. I had the Meziere sitting next to me, and a bucket handy (sitting where the air filter box was). Popped the stock WP out, dropped it in the bucket, and slipped the eH2O pump in. I lost maybe a quart of coolant (most of which was caught in a drip pan under the car).
This water pump is a god-send at the track, especially when combined with a remote switch for the radiator fan. I can cool the car down to under 170* in less than 5 minutes.
Old Sep 11, 2006 | 10:00 PM
hawgman's Avatar
Yup, that bottom bolt is a piece of cake. All it took was being lazy and a little beer logic
Old Sep 11, 2006 | 10:12 PM
If I understand correctly I'll need a shorter belt with the H2O pump since I already have a UDP installed? Or do I need a longer belt?
I think I need a shorter belt but I just want to make sure.
So basically when you take out the stock H2O pump, the coolant fluid will pour out of the hole until you install the the new H2O pump?
I'm beginning to think I can do this myself.
Should I do it?
Old Sep 11, 2006 | 11:36 PM
A shorter belt: I picked up a Dayco #5060995 Poly Cog belt http://www.daycoproducts.com/daycowe...y_Cog?OpenForm. Others have used Goodyear Gatorback or just a regular serpentine belt. 99.5", but I read that someone had to use a 99" as they found 99.5 a little too long.
That's correct. I think I'm going to drain mine first.
Should I do it?
I think I'm going to be doing mine Wednesday night if you want any more info. I picked up the add-a-fuse thingy from crappy tire tonight. Still trying to figure out what to lube the o-ring on the H2O pump with though. White lithium? Synthetic grease for polyurethane bushings? I think someone said aviation grease but crappy tire didn't have that. They did have water resistant Marine grease! Oh wait, I have some plumbers synthetic grease...that should do the trick.
Reminder to self: pick up 6mm ball end allen wrench tomorrow....
Old Sep 11, 2006 | 11:43 PM
don_w's Avatar
I used Vaseline...
Old Sep 12, 2006 | 12:33 AM
What is this add-a-fusy thing??
In the post mentioned above, somebody used a T-tap:
Should I use the T-tap or the add-a-fuse thingamy jig?
Old Sep 12, 2006 | 02:43 AM
To lube the O-ring on mine I bought a small packet of lube at Autozone made for seals. it was like 99cents.
Old Sep 12, 2006 | 08:05 AM
The T-tap comes with the optional relay wiring kit. Did you get the kit?
