Meziere install and the relay ignition-on sense wire
Old Sep 12, 2006 | 11:46 AM
LordBritish's Avatar
Originally Posted by Redfire 05Gt
The T-tap comes with the optional relay wiring kit. Did you get the kit?
Oh I c. I haven't purchased either the pump or the wiring kit yet. I'm just asking as many questions as possible before I pull the trigger.
Old Sep 12, 2006 | 09:40 PM
gkaufman's Avatar
And what do we refill the coolant back with? Just the coolant from the catch bucket(clean)? Im getting ready to buy this kit from brenspeed and Im a little nervous I might screw up. Seems like such an important piece .
Old Sep 12, 2006 | 10:45 PM
Redfire 05Gt's Avatar
That's my plan...
Old Sep 13, 2006 | 02:54 AM
thump_rrr's Avatar
Originally Posted by don_w
I used Vaseline...
Hey Don,
For what it's worth don't use a petroleum based grease on O rings whenever possible. Use a silicone grease such as Dow Corning 111 $17.50/5 oz. tube.
Old Sep 13, 2006 | 10:58 AM
dustindu4's Avatar
9 is not my lucky number.
I used a mini fuse add-a-line to get the switched power, but I had to put it in the fuse box inside the car since there's no place for it on the fuse box in the engine compartment. If somebody made that work I'd like to know how. Then I ran a wire through the firewall.
The bottom bolt is a joke to put in. I have NBA star sized banana hands and I just reached under the pump and stuck the bolt in with my hands and tightened it with a hex L key. Was the easiest part of the install.
On the gasket you can get special O-ring lube, don't use vaseline, it degrades rubber materials. I just wet the thing with coolant and inserted it gently. Push it in place by hand then screw it in in a star pattern to slowly and evenly push it in.
I bought a Goodyear 99.5" belt to use with my Steeda UDP and it was too long, I had to get a 99" one. If somebody wants to buy my Goodyear 99.5" belt let me know.
I had a lot of issues with my water pump, after 2 pump failures/overheated engines I finally got it worked out. You can read about how I fixed them here
http://www.modularfords.com/forums/2...ems-61545.html
I did a step by step install thread on this a while ago, but since the forum crashed twice I refuse to do anymore on this board, I do all mine on Modular Fords now. Besides all the good technical people here are gone now and went there.
Old Sep 13, 2006 | 12:27 PM
Wow, so using the relay included in the wiring kit is not advised because it's not water proof?
I'm gunna have to really think about how I want to wire this.
Seems like waterproof relays are not expensive - less than $15.
Old Sep 13, 2006 | 12:53 PM
thump_rrr's Avatar
For clarification you mean 2 relay failiures. I believe your pump has never failed.
Old Sep 13, 2006 | 08:59 PM
FireFighterHill's Avatar
I used a painless wiring relay kit. I have it all bolted down and secure and have yet to have a problem.
Old Sep 13, 2006 | 10:15 PM
How's this relay - really cheap too
http://www.partsexpress.com/pe/showd...number=330-079
Old Sep 13, 2006 | 10:56 PM
Did you use the add-a-fuse on one of the circuits in the passenger compartment fuse panel?
Old Sep 13, 2006 | 11:08 PM
Can't complain about the price, but it doesn't have a matching waterproof socket like the Hella and Omrons do.
Old Sep 13, 2006 | 11:16 PM
Found a page with Hella and Omron waterproof relays:
http://www.route66supply.com/store/page85.html
What sort of wires should I use?
Old Sep 13, 2006 | 11:34 PM
i used the add a fuse on the engine bay fuse box, fuse number 13 I think. I found a diagram of which ones came on with ignition.
Old Sep 13, 2006 | 11:36 PM
The wiring kit uses 12 ga from the main +12 volt source with a 20amp inline fuse and 14 ga everywhere else.
Could you provide a link to this add-a-fuse thing - thanks.
Old Sep 13, 2006 | 11:38 PM
I looked for it couldnt find one. I found it at autozone though. It takes place of a existing fuse and on the top has a place for two fuses. One for the original accessorie and one for the add on.
Old Sep 13, 2006 | 11:49 PM
#13 in the engine bay Power Distribution Box is a large 30A fuse for the Convertible top (which my coupe doesn't have!)
Attached Thumbnails Meziere install and the relay ignition-on sense wire-power-distribution-box-001.jpg   Meziere install and the relay ignition-on sense wire-power-distribution-box-002.jpg
Old Sep 13, 2006 | 11:55 PM
Mine is made by Littelfuse, part #FHM200BP or OFHM0200ZP
Attached Thumbnails Meziere install and the relay ignition-on sense wire-add-circuit.jpg
Old Sep 14, 2006 | 12:01 AM
yeah thats it above. If I remember to in the morning ill check which slot its in.
Old Sep 14, 2006 | 01:12 AM
  #40
If I understand correctly, that add-a-fuse plugs straight into the socket marked #13.
I've circled the socket that looks like the correct one. Correct me if I'm totally wrong
Looking at thd picture of that add-a-fuse posted above, it appears that you plug wires into it? The blue part of the thing. Is there some special plug or do just solder wires to it?
And how do you get the wires out of the fuse box ? Drill a hole in the box?
One other thing, the add-a-fuse thing has 2 "male" prongs and so does that socket I have circled - so it's obviously not going to fit. That would be a homosexual connection and that's not going to work. I must be missing something basic.
Attached Thumbnails Meziere install and the relay ignition-on sense wire-power-distribution-box-002.jpg
