Meziere Electric water pump group buy
#101
<div class='quotetop'>QUOTE(GIG4FUN @ January 27, 2006, 4:46 PM) Quoted post</div><div class='quotemain'>
Nice and fast with that reply !! Thank you, I appreciate the work you saved me.
Russ
[/b][/quote]
Thanks,
Up next is a performance brake package group buy. Last month I installed a set from StopTech and they are awesome. The fit was perfect and the function is great. I thought the car stopped well stock but now it is much much better. I will have three versions to choose from. Stage 1, 2, and 3. I will start a post on it for you members today.
Russ
[/b][/quote]
Thanks,
#102
<div class='quotetop'>QUOTE(dustindu4 @ February 2, 2006, 7:27 AM) Quoted post</div><div class='quotemain'>
so who has put theirs in? Nobody is talking
[/b][/quote]
Even though mine wasn't part of the group buy, I thought I would post a comment on the pump. As part of the KB installation, the wiring and relay for my pump was relocated. When I was dealing with the fuel leak issue earlier this week, whenever I turned the key on, the pump relay would make a loud buzz. It turned out that the connector on ground wire for the relay was a little loose, and was causing the buzzing. Simple fix.
[/b][/quote]
#104
<div class='quotetop'>QUOTE(Kluski @ February 2, 2006, 11:14 AM) Quoted post</div><div class='quotemain'>
I got mine, but I also have a Shaker Scoop coming in. So I am waiting to everything at once.
[/b][/quote]
I had a different brand of UDP's than Steeda... SO I sold them and bought just a Steeda SFI approved underdriven crank pulley. Well is came without the bolt, so I am waiting for the bolt before I do my install.
I am in on the brakes if they're not too expensive. I woudl like some giant front rotors et cetera as I have the 64W wheel option. I have room!
Thank you again fo rthe group buys....
Russ
[/b][/quote]
Russ
