K&N Aircahrger Kit
Old Jun 23, 2005 | 01:55 PM
KenP's Avatar
Ok, I have the K&N. Have everything almost put together, but i'm stuck on something stupid. Any secrets to putting on this edge trim on the heat shield correctly? can start putting it on, but cant get it to fit right in the corners or the round edges. It's probably something simple, butits getting the better of me.
Old Jun 23, 2005 | 05:24 PM
SS05GT's Avatar
I cut a V shape in the slide-on part at the corners. Do not cut through the rubber gasket material as that will bend easily around. Was able to make it around the rounded outside corners okay without cutting using a rubber mallet to tap/bend around them.
Old Jun 23, 2005 | 06:22 PM
MaverickMLFD371's Avatar
i just pushed it on there hard until it clicked in, took a while and a lot of strength, but its on now and it works.....
Old Jun 23, 2005 | 06:47 PM
Ranger's Avatar
Used gloves and as previously recommended, a rubber mallet. When the gasket goes on like it is suppose to, you will know it.
Old Jun 23, 2005 | 08:20 PM
mustangshadow's Avatar
I actually spread apart the metal in the gasket a tad just to slide it on better and then once on I pinched it tight. Work with it a little bit and you'll get it.
Old Jun 23, 2005 | 10:29 PM
KenP's Avatar
Thanks for the help. Managed to get it on. A little snip here and there made it a bit easier. Don't think I want to be trying to put this on at midnight, so I think I will wait till tommorrow to put it on.
Thanks again.
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
GeoWett
Sep 30, 2015 06:40 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 16, 2015 06:44 PM
