Installed Champion Plugs
Old Apr 10, 2008 | 08:34 AM
  #221
Rash's Avatar
Originally Posted by dustindu4
Car ran fine today, must have been the dirty MAF
Glad to hear it. Also makes me feel better about installing the Champions soon. What did you use to clean the MAF?
Old Apr 10, 2008 | 09:02 AM
  #222
dustindu4's Avatar
9 is not my lucky number.
I got MAF cleaner at pepboys. If you can't find it, you can get electronics cleaner and it works the same I think. Lots of people use either one. It's kept on the shelf near the carb/brake/etc cleaners at the parts store
I usually have this issue every time I reoil the filter
Old Apr 10, 2008 | 09:06 AM
  #223
Boltzman's Avatar
how much for a new filter? I don't want to have the same issues and I don't drive my car around that much so it would be worth it for me.
Old Apr 10, 2008 | 09:07 PM
  #224
dustindu4's Avatar
jlt filter is 50
Old Apr 11, 2008 | 03:21 AM
  #225
theedge67's Avatar
You can also look into the Amsoil filter, check the link in my signature. It is a dry filter, no oil, and you can clean it with a vacuum or shop air. I have it and like it a lot. Just another option for you.
Old Apr 11, 2008 | 06:37 AM
  #226
dustindu4's Avatar
would need a retune?
Old Apr 12, 2008 | 04:40 AM
  #227
theedge67's Avatar
Amsoil filter would not need a retune. I asked Amsoil about this and they said that as far as airflow was concerned, it was very similar to the stock JLT filter made by S&B.
Old Apr 12, 2008 | 08:43 AM
  #228
mco05gt's Avatar
Not sure if anyone has asked yet, but has anyone tried Seafoam first? That stuff worked really well for removing carbon buildup in my rangers 4.0l. When I pulled the plugs they looked like they just came out of the box.
Old Apr 12, 2008 | 04:48 PM
  #229
ohnoesaz's Avatar
Hey guys, I just want to throw it out there that Summit is now charging $15.99 a plug. Still cheaper than other places, but certainly not cheap like the first people who found the deal!
Darn.
Old Apr 12, 2008 | 05:48 PM
  #230
dustindu4's Avatar
good now i don't feel so awful for spending 17
Old Apr 14, 2008 | 10:56 AM
  #231
seabiscuit's Avatar
For your information guys
I just spoke with Superchips Technican, so guys which supply my tune and they suggest to re-gap the Champion spark plugs to 0,054 like Motorcraft standard gap as this is what the tune and the engine was designed for.
On lower gap they expect some problems like i.e. irregular /uneven engine work on low rev.
I think I will re-gap them to 0,054 immidiately when I got them.
What you think?
Old Apr 14, 2008 | 12:07 PM
  #232
dustindu4's Avatar
I thought the motorcraft standard gap is .045? where did .054 come from?
Old Apr 14, 2008 | 12:47 PM
  #233
Robbieg's Avatar
.054 came from Ford, I think thats been the factory gap since the 4.6 came out in the '96's.
Old Apr 14, 2008 | 01:39 PM
  #234
seabiscuit's Avatar
Go MotorCraft website part catalogue
http://www.motorcraft.com/catalog.do
chose Mustang GT 4,6 chose spark plugs and you will get a spark plug with 0,054 gap
BTW AUTOLITE Part # HT1 is also 0,045
Old Apr 14, 2008 | 02:23 PM
  #235
Kryten's Avatar
I been running the Champions for a couple weeks at the .045 gap and my take is that the car starts faster and runs as well, if not a bit better than with the stock plugs
I pulled out at 11,000. Low rev/high rev, cold engine/hot engine, these plugs are working smoothly.
Now I have no idea if this will hold up long term over 1,000's of miles, but the plugs are working satisfactorily right now.
I sure don't see any reason to change the gap, it meets the specified range in the owner's manual (which I found the stock plugs
sure don't with .054 being about what I found).
What you think?
Old Apr 14, 2008 | 04:30 PM
  #236
seabiscuit's Avatar
hmm you are right Manual page 224 Spark Plug Gap 0,040-0,050
Old Apr 18, 2008 | 10:32 PM
  #237
kov68's Avatar
I didn't know where to post this but I've got a set of (8) Champion #7989 Spark Plugs New in the Box for sale. $115.00 Shipped USA 48 States w/ Paypal. Email Me if Interested!!
Old Apr 19, 2008 | 08:01 AM
  #238
07Foose's Avatar
Here is a link to the new Ford TSB 08-7-6 (April 1, 2008) and pic of broken plugs.
http://f150online.com/forums/showthread.php?t=328090
It should how to remove the porcelain by gluing a rod in place of the electrode. This is going to increase the plug replacement bill. ...
Old Apr 19, 2008 | 11:25 AM
  #239
RadBOSS's Avatar
One probably should follow the recommended gap by Ford.
I believe the gap has a strong influence on the discharge energy produced by the coil. I believe it takes more energy to jump a bigger gap. This does not mean that more than specified gap is better, but less than may result in less spark energy.
I am glad I stumbled on this thread. Pretty incredible the design got this far considering all the prototype testing Ford must have done before putting this into production.
I wonder how much influence the gasoline we use has on this problem with the carbon buildup.
It sounds like it is prudent to follow the TSB spark plug removal procedure, no matter the miles on the engine. Who would have thought you would have to go to such extremes though for such a simple procedure?
Old Apr 19, 2008 | 06:57 PM
  #240
theedge67's Avatar
Wow, finally a TSB pertaining to the Mustang on the spark plug issue.
