Hurst Shifter Squeaking (not rattle issue) - Please Please Help
Old Oct 31, 2009 | 02:15 PM
Woodward Ave's Avatar
Unhappy Hurst Shifter Squeaking (not rattle issue) - Please Please Help
So I've had problems with my Hurst shifter since I first installed it.
The first problem was a cross threaded bolt up front in the tunnel (fixed by cutting the bolt down and locktighting - its fine I just checked).
Then the second issue was rattling which i still can't fix. I tried fixing it by spraying lubricant on top of the shifter and also using padding between the handle and base - this worked for a while but not it's back - oh well.
The third issue was a squeeking noise that developed after the winter when going over bumps, found out the shifter linkage was on too tight and didnt have enought lubrication - fixed or so I thought.
So now here is my latest issue:
When I move the shifter arm to the left or right it squeaks.
+I know it isnt the boot, I took it off - I tried cleaning the top of the shifter bearing and putting some white lithum grease on it, doesnt seem to be working.
I took the Shifter handle off and moved the handle base stub - it still squeaks so its nothing to do with the handle. I tried going under the car and disconnecting the shifter linkage so I could lubricate it properly, but unfortunately it is stuck so I did my best to rub some lubricant around. So I think it is one of two things:
+Linkage needs lube
+bearing is squeaking
here is the odd thing, it doesnt squeak moving forwards or backwards through gears. When I brake sometimes I will hear creaking from the shifter. if I put the shifter in neutral move it to the left or right, it squeaks, however when it goes back to center and I move it to the same direction again, it doesnt squeak. But if I move it to the oposite direction and then back it squeaks.
Any Idea which problem it likely is?????? What a nightmare
Old Oct 31, 2009 | 02:30 PM
tom281's Avatar
Don't know what to tell you about the Hurst. But here is three words of advice:
M
G
W
Old Oct 31, 2009 | 02:35 PM
Doogie's Avatar
If you have the comp plus, Ford Racing just came out with a rebuild kit that may help http://www.fordracingparts.com/parts...KeyField=11230
Or you could just use Tom's advice
Old Oct 31, 2009 | 04:54 PM
WaltM's Avatar
How old is it? IIRC, Hurst had problems with the initial run of shifters that had a bad bearing. Call them and they'll probably make it right...
Old Oct 31, 2009 | 08:14 PM
MTAS's Avatar
Old Nov 2, 2009 | 04:26 AM
IHVOCD's Avatar
There's a plastic cup thats on the linkage that you need to spray WD40 on. I had the same problem till I did that.
Old Nov 2, 2009 | 09:49 AM
what did you use to lubricate it?
Old Nov 2, 2009 | 10:19 AM
WaltM's Avatar
Good info. I didn't know it was available.
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
Jul 8, 2016 08:53 AM
09-gt/cs
Oct 15, 2015 10:03 AM
